First post, by iraito
- Oldbie
I got a voodoo 5 and while searching for a better cooling solution I happened to find this https://www.voodooalert.de/board/forum/index. … 2-plus-version/
It took me less than 24 hours to convince myself that I could do this with my preferred choice for retro heatsinks, i started the project today and everything seems to be going well, there's a slight inclination of the screws but I guess thanks to the rubber it shouldn't be a problem, also the pressure is pretty good, I will probably need to pull some weird mod for the second cooler to make it fit with the first one though.
If you wanna check a blue ball playing retro PC games
MIDI Devices: RA-50 (modded to MT-32) SC-55
