First post, by jimnastics
Having a 'mare here with Little Big Adventure and hope you folks may have some ideas. I have a Pentium 75 machine with a Soundblaster 16 (CT2940).
I've restarted into DOS mode from Windows 95. installed LBA from CD as per norm, set up the sound as I believe it should be in setup.exe - I choose Soundblaster 16 for music and select 220 and Soundblaster 16 for sfx and 220 again, simple as. But when I play the game I get no speech and then the game crashes before loading the first level. I've tried various combos of choices (SB Pro, SB16 wave blaster etc.) and no joy. I've tried having the voice files on HDD, no luck.
Here is my config.sys:
DEVICE=C:\Windows\HIMEM.SYSDOS=HIGH,UMBDEVICE=C:\Windows\EMM386.EXE NOEMSFILES=30STACKS=0,0BUFFERS=20DEVICEHIGH=C:\Windows\COMMAND\ANSI.SYSDEVICEHIGH=C:\VIDECDD.SYS /D:MSCD001
Dosstart.bat:
SET BLASTER=A220 I5 D1 T6 P330 H5SET PATH=C:\Windows;C:\LH C:\WINDOWS\COMMAND\MSCDEX.EXE /D:MSCD001LH C:\CTMOUSE.EXE /R2
If anyone can spot any problems in the above, or suggest settings or configs I can try, I'd be very grateful!
