Reply 25580 of 27752, by DerBaum
- Oldbie
DerBaum wrote on 2023-10-14, 15:49:Thanks. […]
smtkr wrote on 2023-10-13, 23:44:DerBaum, that looks professional. Very nice job
Thanks.
Already working on the next one 😁
At the moment i reroute the cables, do some small fixes and make it look nice from the inside.
Window 2 done... Same procedure as the first one.
Before:
I had to remove a bent metal corner from the drive cage because it was touching the original side panel and with the new window it was a little bit tight. I used the same rubber stuff to make the drive cage look a little bit better.
It was the same like on the right side just pointing upwards...
Cable management took a day but looks quite tidy for an old industrial system i think.
I even managed to hide all the power cables in a unused drive bay.
I replaced the IDE cables with fancy ones that also look really nice.
To give this system some Sound i installed a Soundblaster 5.1 VX i had in a corner.
I removed a 4xSerial card and a CAN Bus controller from the system, but i left a huge DSP card in it just because it looks neat. I dont even have drivers for this card and cant find any information about it.
FCKGW-RHQQ2
