First post, by iraito
It looks dead but I have a feeling it's a bios issue, the GPU warms up, windows sees the card as GeForce ddr in the peripherals, nvflash sees it.
I need a good known bios so I can safely flash it and see if I can recover the card.
The fact that windows tells me that there's a driver issue tells me that there's hope
If you wanna check a blue ball playing retro PC games
MIDI Devices: RA-50 (modded to MT-32) SC-55
Reply 1 of 16, by iraito
Card saved.
I went to the VGA museum and got the only bios available from creative, it's reference apparently so I guess that helped.
The card had an invalid ID or at least that's one of the info I got during the flashing.
Reply 2 of 16, by Thermalwrong
That's wonderful that a BIOS flash saved it 😀 This'll probably happen with a bunch more cards over the next few years, where the card was equipped with an early flash-rom BIOS. I wonder if powering the card once every few years avoids this, or it's inevitable on everything with flash memory?
It's not like a Geforce 256 is that difficult to fix compared to most cards like a GF4 MX440 card (since they're mostly the same...), but it's great that it was just a BIOS issue and not a more complex one like failed RAM or damaged BGA connection.
Reply 3 of 16, by The Serpent Rider
Thermalwrong wrote on 2023-09-26, 00:14:
Early does not mean anything in that situation. BIOS usually use NOR-flash chip, which is much more resilient than NAND.
Just powering it will do absolutely nothing. You need to rewrite flash memory to renew it.
Reply 4 of 16, by iraito
I'm pretty happy about it especially since I customized a zalman copper cooler specifically for the DDR, to keep it as cool as possible, the only thing is that my ddr is an Asus not a creative one, so there's that.
If anybody happens in this thread you are welcome to dump your gf ddr bios and post it, I wouldn't mind flashing the one specifically made for my card in the future.
Reply 5 of 16, by iraito
Ok something weird happened, i start the PC today to test it and every game shows some form of texture\color corruption.
https://streamable.com/tyzqee
https://streamable.com/u1h5v4
https://streamable.com/6z8ow9
Any idea and what could be the cause?
Reply 6 of 16, by The Serpent Rider
Slight memory instability.
Reply 7 of 16, by iraito
I imagined it, i was thinking if the bios i flashed could be the cause, what are my options? editing the bios to lower the RAM timing?
Reply 10 of 16, by The Serpent Rider
Ridiculous? Eh, probably memory overclocked the memory. Also I don't see anything missing on the photos above.
Reply 11 of 16, by iraito
Well we have a winner!
I guess the firmware had a slightly lower clocked memory than the one originally used by this card.
Instead of 301 I had to overclock it to 310, works like a charm in every game.
Reply 12 of 16, by iraito
The Serpent Rider wrote on 2023-10-18, 21:36:
The solder joints are flat and opaque in comparison to unused ones, I guess some SMD component was there at some point.
Reply 13 of 16, by Nexxen
iraito wrote on 2023-10-18, 21:41:
Probably a 100nF 10V.
I voted for the weird interference... and lost.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Bare metal ist krieg.
Reply 14 of 16, by BitWrangler
Brainmarking this thread, got one I have to sort out sometime.
Reply 15 of 16, by iraito
BitWrangler wrote on 2023-10-19, 00:37:
I just edited the bios of my gf to 310hz for the ram, so I can simply not care about coolbits etc.
If you have my same card and issue, tell me and I will send you the ROM file.
Reply 16 of 16, by BitWrangler
Mine is a reference design but by SGI I think.
