286 BIOS - 640KB only but 1MB installed (TOPCAT chipset)
First post, by Nexxen
Hello again!!
I just repaired a motherboard and I am puzzled by a problem.
Whatever combination I always get 640KB max of RAM. I do get 512KB with DIP chips or by leaving 2 RAM sticks. 4 will give 640KB.
Present are:
2 x DIP Ram Banks 0 & 1 up to 1MB
4x SIPP sockets with 1MB of RAM.
1x 64KB BIOS chip.
The board:
https://theretroweb.com/motherboards/s/abc-co … 86-a3886-01-v3-
Edit: I can get up to 1.5MB with DIPs + SIPPs. SIPPs = 1MB (4x256). DIPs= 512KB (4*128 + 2 parity).
4 SIPPs should be seen as 1MB but only ever shows 640K.
This is really beyond me as I lack the knowledge on how RAM is connected to the chipset or works on a 286 system.
I assume that it's either a BIOS issue or some component dead.
In the manual page on TRW it's written:
"After installing memory, run the applicable batch file on your setup disk. This loads the
appropriate values into the chipset."
The BIOS chips was an UV erasable, not sure it writes anything. I do have other EEPROMS to test.
I used AMIsetup v2.6 utility and it issued an error:
"Checking 34 .. 7F *ERROR*
Could this be a custom BIOS with a ram limitation by design?
Edit:
- it's due to shadowing, a driver is needed to take advantage of the 384KB.
https://github.com/karcherm/topemm
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Bare metal ist krieg.
Reply 1 of 60, by megatron-uk
I don't know if it is applicable in this case, but many 286 boards are an OR setup with dip and sipp/simm banks... There are exceptions, but it's usually one or the other - not both.
Is there no means to access the bios to do any setup in there?
https://www.target-earth.net
Reply 2 of 60, by jakethompson1
AMISETUP is for AMI HiFlex BIOS; this 286 BIOS is too old and I don't think has hidden options anyway.
It's likely that in the 1MB configuration, the chipset is programmed for shadowing on and relocation off. If you can disable all shadowing, hopefully the bios enables relocation giving you 384K of extended memory.
Because this board uses an 8-bit BIOS chip, it was designed to be used with shadowing on, however.
Reply 3 of 60, by Nexxen
megatron-uk wrote on 2023-10-21, 23:33:
DIPs + SIPP works, as 512KB of DIPs + SIPPs gives 640KB.
The DIPs are mine, 70ns like the ram. It was a test. I get the same 512KB if I leave just 2 SIPP sticks.
No options in BIOS, it's the b&w with just basic options.
I'm looking for a BIOS, the ones that come in pink+brown... commonly found on 386s. It's an idea, not a certainty it'll work. 😀
jakethompson1 wrote on 2023-10-21, 23:36:
Any idea what program I should use to try anything?
There are aonly BIOS and VIDEO shadow, both enabled or disabled does nothing.
Shouldn't ram exceeding 640 appear anyway? IDK, prolly a custom bios to limit machines and avoid "workers" to play? 🤣
Reply 4 of 60, by Jo22
There's an EMS driver on the page.
So I assume the board can handle more than 1 MB?
If it was my board, I would remove all RAM and install two SIMMs of 1 MB each (80286 is 16-Bit, 2x 8-Bit SIMMs per RAM bank).
I would just use two slim SIMM sockets and plug them into the corresponding SIPP sockets (as an adapter).
Or I'd just solder pins to a pair of spare SIMMs, pinout is 1:1 identical.
I did this in the past using resistor legs, not pretty but it worked. Though a pin strip would be more elegant, perhaps.
Edit: I forgot to say, I was just thinking out loud. I'm not telling anyone how to do things, of course. Many roads lead to Rome, so to say. 🙂
Reply 5 of 60, by rmay635703
My old 286 systems required me to manually type in how much ram was installed.
Sometimes I had to set a jumper for “bank 0” to tell it what banks were active.
It’s possible that it’s only “seeing “ the sticks of ram giving you 1mb usable which on old systems was only 640k plus UMBs
Also you don’t get 640k + 384 extended unless your board supports relocation.
Relocation + shadow was rare.
Reply 6 of 60, by jakethompson1
Nexxen wrote on 2023-10-21, 23:44:
For whatever reason, AMI always subtracted unrelocated RAM from 640K-1024K from the displayed memory count, while Award did not.
Thus AMI gives odd counts like 3968 KB, 7808 KB, 16000 KB, etc. while Award would display the "expected" amount.
Reply 7 of 60, by Nexxen
jakethompson1 wrote on 2023-10-21, 23:58:
I can't make use of it. I tried drivers for EMS, XMS... nothing. Not even the ones supposed to work 😀
Crazy...
In config and autoexec combos nothing loads beyond 640KB.
I could have made a mistake.
Reply 8 of 60, by Nexxen
Jo22 wrote on 2023-10-21, 23:51:
There's an EMS driver on the page. So I assume the board can handle more than 1 MB? […]
I thought of that. I'd like to solder simm sockets to use above 1MB...
No offense taken, we are here to team up and solve stuff.
Reply 9 of 60, by Nexxen
Guess hte driver isn't working correctly anyway:
see readme.
Edit, maybe broken traces? Again continuity tests... I am a masochist.
Reply 10 of 60, by jakethompson1
Nexxen wrote on 2023-10-22, 00:05:
Crazy...
Your chipset supports more memory maps than what your BIOS allows, it seems:
The attachment VL82C320_DRAM.png is no longer available
It appears you're stuck in mode 1 with shadowing on, which means no EMS and no extended memory.
Alternatives would be mode 1 with shadowing off, no XMS, and with EMS, or mode 1F, with shadowing off, no EMS, and with XMS.
It's possible you could try and poke at the chipset registers with DEBUG after boot, or patch the BIOS to try and use one of these other modes.
I suspect if you turn both forms of shadowing off and then try the EMS driver again, it may work...
Reply 11 of 60, by Nexxen
jakethompson1 wrote on 2023-10-22, 00:18:
Your chipset supports more memory maps than what your BIOS allows, it seems: […]
Crazy...
This is interesting but, alas, non clue how. This is the point I am in the dark.
I'll take pics of the BIOS menu. Wait a wee bit 😉
Reply 12 of 60, by Nexxen
I need a new BIOS.
No idea of compatibles. I can merge odd and evens but don't know how.
Nothing is simple here... 🤣 🤣
Reply 13 of 60, by Nexxen
bios
not much choice...
Reply 14 of 60, by Horun
Ok, I was thinking bios is stuck at mode 3 with shadow since he said he could get 640k (4x256k -384k)... just thinking out loud 🤣
Odd I have a similar bios but has a page 2 where you have to set other RAM items. I noted the bios at Retro is dated 7/1990 and your is dated 1990...
Reply 15 of 60, by Nexxen
Horun wrote on 2023-10-22, 01:19:
If it is in 64KB attach it and I'll test it. THanks!!
Reply 16 of 60, by Horun
It is 64k and appears from a hex edit to be near identical screens as yours but here it is: https://theretroweb.com/motherboards/s/abc-co … 1-v3-#downloads
Reply 17 of 60, by pentiumspeed
That is very primitive bios type. And motherboard and the bios has to be set up to use more than 1MB.
Cheers,
Great Northern aka Canada.
Reply 18 of 60, by Nexxen
Horun wrote on 2023-10-22, 01:25:
That one is mine, I uploaded the image. Better than nothing if there isn't one around 😀
Reply 19 of 60, by Nexxen
pentiumspeed wrote on 2023-10-22, 01:26:
Cheers,
We aren't even getting to 1MB... just 640KB.
