First post, by eesz34
The BIOS in my 386 allows me to set more than 1024 cylinders, but MSDOS fdisk only recognizes 500MB or so. Not surprising. I don't have a lot of use for more in DOS anyway, but I was thinking, could I put an old Slackware release on it since Linux doesn't use the BIOS handler?
I think what I'd have to do is shrink the DOS partition some so the start of the Linux partition is still within the first 1023 cylinders. But, this assumes the relevant files are within this region until Linux takes over the BIOS routines. Has anyone tried this? It seems feasible, but perhaps tricky. Or, maybe I need to make a small boot partition just at the end of 1023 cylinder limit that boots Linux. Not sure how to do that.
