First post, by Kreshna Aryaguna Nurzaman
- l33t
Well, I'm not sure where the problem is located: Dosbox, munt, or just my system. Thus, I post the thread here just to be safe. Feel free to move it elsewhere as necessary.
See, I'm playing Wing Commander 1 using Dosbox and munt. I downloaded the latest munt from sourceforge, and got the MT32_Control.ROM and MT32_PCM.ROM from a link on this forum. I unzipped both munt and PCMs into the same folder: C:\MT32EMU, and then installed it as MIDI device.
Here's the contents of C:\MT32EMU:
COPYING.txtdrumpat.romMT32_Control.ROMMT32_PCM.rommt32emu.dlloemsetup.infpatchlog.cfgPreset1.syxPreset2.syxREADME.txt
And then, I fired up DOSBox with the following configuration:
[sdl]fullscreen=truefulldouble=falsefullresolution=originalwindowresolution=originaloutput=surfaceautolock=truesensitivity=100waitonerror=truepriority=higher,normalmapperfile=mapper.txtusescancodes=true[dosbox]language=machine=vgacaptures=capturememsize=16[render]frameskip=0aspect=falsescaler=normal2x[cpu]core=normalcycles=4000cycleup=500cycledown=20[mixer]nosound=falserate=22050blocksize=2048prebuffer=10[midi]mpu401=intelligentdevice=defaultconfig=[sblaster]sbtype=sb16sbbase=220irq=5dma=1hdma=5mixer=trueoplmode=autooplrate=22050[gus]gus=truegusrate=22050gusbase=240irq1=5irq2=5dma1=3dma2=3ultradir=C:\ULTRASND
[speaker]pcspeaker=truepcrate=22050tandy=autotandyrate=22050disney=true[joystick]joysticktype=2axistimed=falseautofire=falseswap34=falsebuttonwrap=true[serial]serial1=dummyserial2=dummyserial3=disabledserial4=disabled[dos]xms=trueems=trueumb=truekeyboardlayout=none[ipx]ipx=false[autoexec]
Here's the specification of my old notebook (where I play Wing Commander):
Toshiba M20
Intel(R) Pentium(R) M
processor 1400MHz
598MHz, 736 MB of RAM
Microsoft Windows XP Professional Service Pack 2
Now, when I play Wing Commander 1, several sound effects are just missing, as follows:
- sounds of ship's guns firing -=> most notably missing
- explosion
- the closing of the cockipt (before launch)
Sounds effects that still exist:
- engine sound as ship's flying by
- asteroids flying by
What the problems are? Is there anything wrong with my munt, My DOSBox .conf, or my system?
Kreshna Aryaguna Nurzaman.
