First post, by slow_poke
I did this .com file doing assembly language in `93 (and this was done before plug-and-pray. (I understand that vid cards are under this curse) what this does, as a programmer, is to give quick reference to whatcha wanna do. (in daze back then) =D this was done while I was still influenced by ANSII and it reflects the blinking cursor... that is, the text would "blink" on and off when the (B)link key was pressed. ...I don't know if this hAs anything to do with with what DOSBOX wants to do, but it works, but doesn't work. as does veesta. *****NOTE this is a 2kb .COM file ***** I had to rename it `cause all you folks are scared of cooties!. good grief! =D
