First post, by curggles@gmail.com
I have an asust p55t2p4 board I updated to a modded bios 0207_j7 which is supposed to add support to up to 128gb drives. I am currently running a k6-2 400 cpu in the board.
What my issue is no matter what I use to partition my new 16gb compact flash card windows 98 scan disk at setup gives me this error:
ScanDisk cannot read from the last cluster on drive C. This cluster is either damaged, or your system is not configured properly. Drive C may need to have Logical Block Addressing enabled to work properly, or its disk partition may be incorrectly marked as a non-LBA partition
I have tried different bios selections for the cf like auto type and auto mode, fdisk, partition magic, gparted. Made sure lba flag set on the drive. Low level format. And I always get this message right when scan disk starts. I'm currently letting scan disk run and hopefully it will install. Just curious if others had this issue.
Asus p55t2p4 PEntium 200, 48mb ram, Cirrus logic 5446 PCI, diamond monster voodoo 3d, ISA Asus vibra 16.
PCChips m321, am386 dx40, 4mb ram, trident 8900c ISA, Creative labs SB16 CT2230.
Ap43 Intel i486dx4-100 also have a amd am486dx2-66v16bcg.
