First post, by Allannon
Can someone tell me what card this is and is it good for dos ?
    1.41 MiB
    1.71 MiB
Reply 1 of 6, by Shponglefan
It's a PCI video card with the S3 Vision968 chip: https://www.vgamuseum.info/index.php/cpu/item … 55-s3-vision968
It's rated as having generally good DOS games compatibility.
Performance-wise, it's not as fast as the S3 Trio64 in DOS, but would be faster in Windows. Benchmarks are here: Re: Benchmarks for high-end VLB graphic cards - ET4000W32P/ARK1000VL/Trio64/S3 Vision968/Mach64
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 2 of 6, by Grzyb
Dual-ported VRAM.
Below average in DOS games, much better in high resolution/color/refresh modes.
Reply 3 of 6, by The Serpent Rider
No, it's not below average.
PCI Video cards benchmark: Electric Boogaloo Edition
Reply 4 of 6, by Grzyb
The Serpent Rider wrote on 2023-11-04, 18:37:
In low-res, it's definitely near the bottom for PCI cards - http://vgamuseum.info/images/vlask/bench/quake320.png
Edit:
Anyway, your benchmarks perfectly show the difference between regular DRAM (Vision 868) and dual-ported VRAM (Vision 968)...
in low-res, both are poor, 968 being only a little better
in high-res, 868 remains poor, but 968 gets very good indeed
Reply 5 of 6, by The Serpent Rider
There are many cards which are MUCH worse in VGA, it's not the best S3 card though, but on much slower system there won't be any sizeable difference.
That test is not VGA and mostly irrelevant.
Reply 6 of 6, by zwrr
NICE IBM RAMDAC
486DLC-40, 386-VC-H, 32MB, GD5429, ES1868F
X5-133, HIPPO-15, 32MB, Riva 128, ES1868F
5x86-120GP, SYL8884, 32MB, Trio64V+, ES1868F
Pentium MMX-233, T2P4, 128MB, TNT2, SB16
Tualatin-1.4G, 694X, 512MB, G400, Voodoo2, SB AWE32
