mkarcher wrote on 2023-11-04, 23:24:25ns cycle time means 40MHz cycle frequency, which means 80MHz MCLK is in spec, assuming all other timing requirements are also  […]
CoffeeOne wrote on 2023-11-04, 15:10:
Mosel V53C104HP45 (with a "fast page mode read or write cycle time" of 25ns, which I believe is very good)
25ns cycle time means 40MHz cycle frequency, which means 80MHz MCLK is in spec, assuming all other timing requirements are also met at 80MHz.
EDIT: According to the datasheet you attached: The NPN 50ns has a "fast page read or write cycle time" of 33ns, the 45ns type has 30ns at this value.
So the Mosel seems better 😀
This is 60MHz and 66MHz max in-spec MCLK.
I have an update. I used a donor card to get faster 256kx4 chips. The card now looks like that:
 The attachment PXL_20231117_231236466.jpg is no longer available
So OK, I just checked under dos that the card still works => everything was like before.
So I switched directly to 80MHz.
Still everythings seems to be OK, same picture quality as before.
Speedsys Video Throughput is now very high, jumped from +26000 kB/s (65 MHz) to +38000 kB/s.
Dos values are the same, a tiny increase in Doom, small increase in Wolf3D, now new record there.
 The attachment PXL_20231117_223859172.jpg is no longer available
But now to the bad side: No improvements in displaying the modes which are only available with 2 MB.
I tried first 800x600 24bit with 56Hz, same picture (distortions every 2 seconds ,when moving the mouse than more). The mode got much faster though: Wintune 2.0 is now ~ 3300kPixel/s before it was below 2000kPixel/s.
800x600 24 bit 60Hz similar as before not usable at all.
I tested then 1280x1024 256c @60Hz, this can be done without needing the Ark Tools:
So switching to 1280x1024, I have a good picture for one second.
 The attachment PXL_20231118_114446008.jpg is no longer available
Afterwards the colours change: Sometime into the blue, more often into the yellow. Then the pictures stays like that:
 The attachment 1280second.jpg is no longer available
So what is the problem?
1) Card damaged during the soldering?
2) Second megabyte too slow, too bad?
3) The Ark 1491 is not really a 110MHz type and needs to be exchanged?
The most easy point to change for me is point 2. I can get Mosel 45ns 256kx16 ram chips easily. Even more easy would be using Edo chips, can it work? I have V53C16258HK35 chips.
EDIT / UPDATE: I tried the 35ns EDO RAMs, there are distortions also already in 1024x768 mode which is fine with the Fast Page mode ones.
Also tried more combinations of the 2 Rams for the second megabyte, because I have 4 of those in total. Behaviour does not get better: 1024x768 is fine, but colours change randomly in runtime in the 1280x1024 60Hz mode.
So I don't think it is point 2. Also I cannot find anymore the Mosel 45ns 256kx16 chips , ......
