First post, by kolmio
On my old Acorp 6BX86, there's one USB 10 pins connector.
And I don't have its original extender.
I installed it into ATX case and its 2 front USB sockets are connected by a 9 pins plug.
So I checked pinouts and it turns out that the one with 9 pins has same signals on left and right side,
while 10 pins one has left and right side rotated (see images).
I was able to connect one of front panel USB sockets by shifting the plug one row aside. But I'd like to have a nice adapter to connect both sockets.
It's not too difficult to solder one, but maybe there exists a factory made?
    43.56 KiB
    87.89 KiB
Windows 95 | Chaintech 486SPM M102.A | AMD-X5-133ADW or Am486DX4-100 | 48MB SIMM FPM | ATI Rage 3D II+DVD | CT4100 | 8GB CF
Windows 98 | Acorp 6BX86 | Pentium II 450 | Matrox Millennium G450 | SoundForte SF16-FMI-03 | 32 GB MicroSD
Reply 1 of 2, by Repo Man11
You ought to be able to customize the case's USB cable by (carefully) lifting the plastic retainers and arranging the pins to match. Image shows a pair of five pin connectors, but the procedure is the same.
Reply 2 of 2, by NJRoadfan
Buy some DuPont pin connectors and make an adapter. Just triple check the Vcc and ground connections, otherwise you'll blow a pico fuse on the motherboard.
