Reply 50820 of 52977, by nfraser01
BitWrangler wrote on 2023-11-06, 17:32:
Oh wild, I guess my chances of coming across one of those are next to zero outside of UK. I guess the earlier Archimedes PC emulator thing needed a hardware lift.
Most Acorn computers from the BBC onwards allowed more than one CPU inlcuding different architectures. Amazing stuff.
Reply 50821 of 52977, by schmatzler
I got an ATI Radeon All-In-Wonder 8500DV with all of the accessories.
The card even comes with a nice, passive Zalman cooler (ZM17-CU) and it seems to have been rarely used, because it smells like a new car and even the ATI Remote does not have any wear on the rubber parts.
601.69 KiB
501.14 KiB
This is amazing. I'm gonna test this thing out soon - I wonder if the USB-Remote still works on Windows 11 or if it needs special drivers to function. Maybe it'll run on Linux? 😁
The only thing I'm not sure about is this VGA adapter that breaks out into Composite and S-Video. Did that come with the card? It just seems to be a direct cable. I don't think it's possible to adapt VGA straight to these standards, or is it?
108.81 KiB
Reply 50822 of 52977, by DerBaum
schmatzler wrote on 2023-11-06, 22:54:
The only thing I'm not sure about is this VGA adapter that breaks out into Composite and S-Video....
I have 2 of those... I think they came with Matrox cards...
FCKGW-RHQQ2
Reply 50823 of 52977, by liqmat
Picked this up for ~65 USD on the streets of Japan.
1.69 MiB
1.09 MiB
Reply 50824 of 52977, by BitWrangler
Baroque, but what was it a CPU card for in the first place? Or don't you care and are going to use the upgrade on something else?
Reply 50825 of 52977, by ubiq
I got an ATI Radeon All-In-Wonder 8500DV with all of the accessories. The card even comes with a nice, passive Zalman cooler (ZM […]
I had this (or similar vintage) All-in-Wonder and that VGA thing def did not come with it. Looks like you got everything else though. I loved that remote - rf-based, not IR, and it could act as a mouse. 😎
Reply 50826 of 52977, by Shponglefan
nfraser01 wrote on 2023-11-05, 19:10:
Never mind the trinity, that's a tidy workshop!
Thank you!
It's a bit deceptive though, because I just shove the mess out of frame when taking pictures. 😁
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 50827 of 52977, by nhattu1986
I got this HP 220mx MO jukebox from a friend (because his wife complain about the its size take up much space at home)
and oh boy, that thing is soooo big that it surprise me when i seen it for the first time.
453.89 KiB
there are a lot of dust inside the drive, i had to dismantle the MO drive to access the lens to clean it.
at least sony is kind enough to made the pickup unit can be replace without worry about messing up the alignment.
360.68 KiB
Reply 50828 of 52977, by liqmat
BitWrangler wrote on 2023-11-07, 02:02:
The upgrade and the price was most definitely the attraction. Not sure what Epson system it came out of, but I’ve had no time to research.
Reply 50829 of 52977, by EvieSigma
liqmat wrote on 2023-11-07, 03:43:
After looking at it pretty thoroughly, I think this is a somewhat hacky upgraded version of a Epson PC-286 (an Epson PC98 compatible) CPU card.
Reply 50830 of 52977, by 3lectr1c
3lectr1c wrote on 2023-11-06, 13:34:
Unfortunately, I don't have the proprietary PSU for the Nan-Tan laptop, so I can't test it. Visually it looks good inside though, pulled the clock battery before it could completely explode.
I found the PSU for this one on eBay! I hope it works 😀
I probably have too many old laptops.
Reply 50831 of 52977, by DerBaum
DerBaum wrote on 2023-11-02, 16:53:
Because i dont feel confident in finding the failure in the drive i destroyed... i bought another one. […]
DerBaum wrote on 2023-10-08, 21:53:
Now the really bad news.
I think i have killed the 5 1/4 floppy drive...
I bought a very similar model so i can swap the faceplate to the brown one my drive has on it.
The drive i got is untested... wich is not a good sign in general... but it was the cheapest one for 30 euros.
Who the hell decided that a used untested floppy drive is now 30 bucks? depressing...
At least it looks clean...
I think today or tomorrow i have time to test it.
I am surprised that nobody has seen it...
But now i know why the drive was "untested"...Always the same thing with these seller idiots.
Can you see it? I feel so stupid for not seeing it. And now i need to repair this drive too if it is even fixable.
i will need some extremely high resolution reference pictures of a not broken drive.
edit: correction pictures are not enough... i need somebody with the exact same drive who is abled to make 5 or 6 measurments for me...
FCKGW-RHQQ2
Reply 50832 of 52977, by weedeewee
DerBaum wrote on 2023-11-08, 16:31:
I am surprised that nobody has seen it... But now i know why the drive was "untested"...Always the same thing with these seller […]
edit: correction pictures are not enough... i need somebody with the exact same drive that i abled to make 5 or 6 measurments for me...
I don't see it looking at the photos.
Any clue ?
Do not ask Why !
Reply 50833 of 52977, by TheMobRules
Broken edge connector?
EDIT: I agree, it's really annoying to have to play "Where's Waldo?" with these sellers and their "untested" items
Reply 50834 of 52977, by DerBaum
TheMobRules wrote on 2023-11-08, 17:13:
100 points ... 1 to 4 are missing...
You cant imagine how irritated i was when i wanted to plug it in...
1.39 MiB
EDIT:
i have started to remove the soldermask to see the traces.
1.32 MiB
1.75 MiB
the backside is just ground thats easy... on top about 4 traces are gone with the piece of the connector...
my first guess it should look something like this: but i need confirmation first before trying to make a piece to repair it.
255.17 KiB
FCKGW-RHQQ2
Reply 50835 of 52977, by TheMobRules
DerBaum wrote on 2023-11-08, 17:16:
I think that extra card edge under the power connector makes it even more confusing, it's easy to miss at first glance... I wonder how compatible this PCB is with the drive from your original post, both are FD-55GFR right? Maybe you can get one working drive out of those two.
Reply 50836 of 52977, by DerBaum
TheMobRules wrote on 2023-11-08, 17:22:
they are extremely different. the original drive has a head loading machanism with an electro magnet and the head is connected by wires also the stepper has wires.
on the newer drive there is no head loading mechanism and everything is flat cables. they are around 5 years apart.
My guess that on the original drive the electronics are toast... but all chips are different from the new one.
Yes the extra connector is confusing. its a test connector presumingly for factory testing.
one of the damaged traces goes to this connector. so i hope that i have to repair one trace less (because i dont care if the test connector works) 😁
maybe i can even cut off the test connector and use it as a replacement part... i have to investigate how i can make pcb or where i can cut off a piece of an edge connector. i also have some donor isa cards like modems or isdn cards.
FCKGW-RHQQ2
Reply 50837 of 52977, by Lutsoad
Don't feel bad. I once bought two Pentium Pro boards and failed to notice that one didn't have the PAL chip and the other had like 10 components cannibalized. I was too excited to finally build my first PPro system. Can't blame anyone else but myself. Never a dull moment with retro stuff!
Reply 50838 of 52977, by DerBaum
CharlieFoxtrot wrote on 2023-11-02, 18:36:
I have one 7193-U and it is manufacterd in 1993.
Is it possible that you measure some connections for me?
just beep out some things. nothing fancy
310.84 KiB
1 is the Pad on the test connector
2 and 3 are the missing pads
4, 5 and 6 are vias.
I made a small chart of the measurments i need.
1.81 KiB
1 to 2,3,4,5,6
2 to 3,4,5,6
3 to 4,5,6
4 to 5,6
5 to 6
Thanks in advance.
I expect:
1 to 6
2 to 5
3 to 4
FCKGW-RHQQ2
Reply 50839 of 52977, by ubiq
This showed up today:
1.35 MiB
I tossed $10 at an eBay auction with no bids and ended up getting it. It came with CPU, RAM and a I/O faceplate. Looks like it actually works!
1.3 MiB
