Reply 50840 of 53143, by Kahenraz
DerBaum wrote on 2023-11-08, 22:39:
Is it possible that you measure some connections for me? just beep out some things. nothing fancy […]
CharlieFoxtrot wrote on 2023-11-02, 18:36:
I have one 7193-U and it is manufacterd in 1993.
1 is the Pad on the test connector
2 and 3 are the missing pads
4, 5 and 6 are vias.
I made a small chart of the measurments i need.
1 to 2,3,4,5,6
2 to 3,4,5,6
3 to 4,5,6
4 to 5,6
5 to 6
Thanks in advance.
I expect:
1 to 6
2 to 5
3 to 4
It might not be possible to repair this reliably for insertion and removal. But what you can do is cut away part of the protective housing of a connector and solder a bodge wire from from the pins to the PCB. Then, add some hot glue for mechanical support.
Reply 50841 of 53143, by DerBaum
Kahenraz wrote on 2023-11-09, 02:16:
Because i am a little bit insane i drilled 2 0,7mm holes inside the pcb and the part i cut out of an old isa modem...
then i inserted pins from a pin header into the holes and superglued it together. the tiny gaps (where you could see superglue) i have filled with pcb saw dust from cutting the replacement.
it feels rock solid. i am actually surprised that it even worked...
1.06 MiB
1.61 MiB
1.93 MiB
Now i just need confirmation of the traces.
FCKGW-RHQQ2
Reply 50842 of 53143, by BitWrangler
Well done, you just pocketed $6000 if you were a dentist 🤣
Reply 50843 of 53143, by DerBaum
BitWrangler wrote on 2023-11-09, 02:41:
That would be awesome.
If i count the hours that went (and will go) into the repair... that is a pretty expensive drive in the end. If it even works.
But... If you enjoy the job, is it even work? 😁
FCKGW-RHQQ2
Reply 50844 of 53143, by Kahenraz
The only thing I would be worried about, drilling from the side like that, is shorting out a trace, via, or ground plane. You should be able to see what's inside by shining a bright light from the other side.
This is a very old PCB, so maybe this won't be a problem, but it does give me pause. Cosmetically, it looks great otherwise.
Reply 50845 of 53143, by BitWrangler
By the edge of it, only looks like a 2 layer, top and bottom, but yeah, multilayer you need to check you're not cutting or shorting anything.
Reply 50847 of 53143, by DerBaum
Kahenraz wrote on 2023-11-09, 04:32:
The left hole is also very close to two vias. You wouldn't want to accidentally sever or short either of those.
I have checked that. it is just 2 layer. all vias around the drilling area are ground from the top to the bottom. i have calculated to hit them... And then the stabilisation pins are just ground...
but i have not hit them. i measured from the drill bit to all nearby vias and components.
Until now it looks good.
FCKGW-RHQQ2
Reply 50848 of 53143, by liqmat
EvieSigma wrote on 2023-11-08, 00:14:
After looking at it pretty thoroughly, I think this is a somewhat hacky upgraded version of a Epson PC-286 (an Epson PC98 compatible) CPU card.
Great. Thanks for looking into that. Hell of an upgrade for a 286. I think it was worth saving.
Reply 50849 of 53143, by ubiq
ubiq wrote on 2023-11-09, 02:00:
This showed up today: IMG_6272.jpeg […]
I tossed $10 at an eBay auction with no bids and ended up getting it. It came with CPU, RAM and a I/O faceplate. Looks like it actually works!
This fella is newer than what I usually mess with, so I was starting to think I didn't have an appropriate GPU for it when I dug up this thing I actually scavenged locally a while back:
1.54 MiB
1.74 MiB
I must have some sort of mental block, because I just don't remember this era of GPUs. Assuming the hideous HSF is aftermarket. Still, why is the card so weirdly huge yet sparse?
1.19 MiB
1.59 MiB
Anyway it works, FWIW
1.49 MiB
Looks way better without that plastic cladding, get a decent fan on it and might have something. 🤔
Reply 50850 of 53143, by Tiido
DerBaum wrote on 2023-11-09, 02:36:
That is an excellent repair ! What did you use to drill like that ?
Reply 50851 of 53143, by DerBaum
Tiido wrote on 2023-11-09, 12:52:
A local supermarket (Lidl) offered Microdrill sets for their "Dremel" clone.
1.03 MiB
BUT i used the drill just with my fingers to have more control.
The drills are quite sharp. One hole took about 5-10 minutes by hand.
FCKGW-RHQQ2
Reply 50852 of 53143, by debs3759
Brings a new meaning to "hand drill" 😀
Reply 50853 of 53143, by Tiido
I will have to try this at some point, I didn't even think you could hand-drill this way 🤣. Definitely a great idea !
Reply 50854 of 53143, by BitWrangler
For a bit more torque, you can build up the drillbit with electrical tape to give you more to get hold of. There exists a thing called a "pin vise" specifically for doing this kind of thing. Some hobby knife (Xacto etc) sets have an equivalent tool you can get a bit clamped into. Tiny hand drills are a thing that have existed in the world, Tandy/RadioShack used to do one, which even came with a couple of tiny bits. Then also there are newer and older variations on this theme...
https://contenti.com/deluxe-spiral-hand-drill
Which are quite handy also.
I have also found it handy to have a loose small drill chuck, just as a knob/handle for small bits... if you have a hand drill, you can find a bolt same thread as the one the chuck is on and use the chuck by hand for small stuff. That's if it isn't a really cheap chuck that falls apart when you unscrew it all the way or is too low precision to grip anything under 1/8th. (3mm ish)
Reply 50855 of 53143, by acl
DerBaum wrote on 2023-11-09, 12:58:
A local supermarket (Lidl) offered Microdrill sets for their "Dremel" clone. 2023-11-09 13.54.56.jpg […]
I have a lot of tools from them.
Prices are actually good for basic tools.
I think I have a pressure washer, a stand/magnifier/led for my soldering iron. A SMAW welding machine. A few other tools...
Not always the best equipment but generally ok and cheap
Reply 50856 of 53143, by weedeewee
Because i am a little bit insane i drilled 2 0,7mm holes inside the pcb and the part i cut out of an old isa modem... then i ins […]
Nicely done !
looking at the pinout... I wonder, are any of those pins that were missing really required for the computer to interface with the drive ?
Do not ask Why !
Reply 50857 of 53143, by DerBaum
weedeewee wrote on 2023-11-09, 16:56:
Every time i look a floppy pinouts i am more confused than before.
The teac drive is a multi speed drive. It should be abled to read many formats. I am not sure if the density select signal is used for that.
All of the pins that are missing have connections into the circuit (from the number of traces in the area).
FCKGW-RHQQ2
Reply 50858 of 53143, by BitWrangler
ubiq wrote on 2023-11-09, 05:36:
This fella is newer than what I usually mess with, so I was starting to think I didn't have an appropriate GPU for it when I dug […]
Yeah that was a great score for $10 and quite a beast of a GPU you found for it, relative to AGP availability.
Reply 50859 of 53143, by PD2JK
Can't wait to bench this beauty. (Upgrade from a SX 25.)
389.53 KiB
DX4 100 Overdrive SZ959
