First post, by ante1234and
hi!
i have trouble getting winquake to work on my win98 pc, the game starts just fine and runs perfectly but when i'm done playing and exit the game, the computer restarts by itself. what causes this and what can i do to fix it?
my specs:
pentium 3 500 mhz
nvidia fx 5200
384 mb ram
soundblaster 16 isa soundcard
windows 98
Reply 1 of 6, by dominusprog
Check the RAM configurations in BIOS.
Creative AWE64 Value ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 6, by ante1234and
should i change it to a lower ammount of ram or something, how much ram do winquake require?
Reply 3 of 6, by darry
I think that @dominusprog meant that you might want to try loosening the RAM timings in the BIOS.
My guess is that it might be an issue linked to the Nvidia driver version that you have installed and/or the chipset drivers installed (or not installed) if the motherboard uses a VIA chipset.
Reply 4 of 6, by dominusprog
darry wrote on 2023-11-11, 13:18:
Yes, try to increase the timing and also as @darry mentioned try a different driver for both the chipset and the graphics card.
Reply 5 of 6, by Gmlb256
Try running WinQuake with the -dibonly command line switch. WinDirect (the default option that uses VGA and VESA video modes directly) is problematic with some video cards and DirectDraw is slower.
Reply 6 of 6, by leileilol
winquake's problematic with all Geforce cards, always use -dibonly with them.
