Netburst: Aiming for the Stars
Reply 120 of 467, by H3nrik V!
supercordo wrote on 2023-11-17, 20:27:
Benchmarking is fun!!!
It definately is! I'm reliving my early 20's again 🤣 Except back then it was a Northwood 1.6 @ 2.4 😁
Reply 122 of 467, by supercordo
acl wrote on 2023-11-17, 21:06:
Is that your Ti4600 on the picture ? How does it perform compared to the Ti500 ?
Its mine! The Ti 500 is faster since it can use older drivers. All the drivers for the Ti 4600 have more cpu overhead. I havnt tested it yet on my S423 tho.
Reply 123 of 467, by acl
supercordo wrote on 2023-11-17, 21:15:
I was also thinking about this sentence from wikipedia :
It is believed that the fixed-function T&L hardware from GeForce 2 was still included on the [GeForce 3] chip for use with Direct3D 7.0 applications, as the single vertex shader was not fast enough to emulate it yet
This might give an advantage for GeForce3 over the 4 on pure DX7 workloads. The DX7 rendering over programmable pipeline might add some CPU overhead with more complex drivers on the GeForce4.
But not sure if it's true or just a myth
Reply 124 of 467, by H3nrik V!
OK, now ... 118 FSB, 1.875V according to BIOS (I don't like what CPU-Z reads). Memory timings tidied up, AGP @ 72 MHz ...
Where to go for the last 307 points?
Reply 125 of 467, by supercordo
H3nrik V! wrote on 2023-11-17, 21:43:
Updated! You could start looking at optimizing windows?
Reply 126 of 467, by acl
Drivers options can help too : The "quality vs speed" slider. MipMap quality, etc... just set everything to "fast" 😁
Reply 127 of 467, by H3nrik V!
supercordo wrote on 2023-11-17, 21:56:
That's probably outside my capabilites 🤣
Reply 128 of 467, by H3nrik V!
acl wrote on 2023-11-17, 22:02:
Smells almost like cheating, buuuut, the rules doesn't say that I can't 😎
Reply 129 of 467, by supercordo
The first post has been updated with the link to the post for each score. I think its awesome.
Reply 130 of 467, by H3nrik V!
Yay! Looks like a top-3 in 3DMark 2000 - at least because not many has run it 🤣
Reply 131 of 467, by supercordo
H3nrik V! wrote on 2023-11-18, 09:45:
Score updated! Nice.
Reply 132 of 467, by supercordo
Its on now!!! Just need my board to get here.
Reply 133 of 467, by supercordo
If you dont have a test bench yet! DimasTech went out of buisness so these are hard to find. Seller says they have 7 available in New York. Mine arrives on Monday, Ill let you know if i like it. https://www.ebay.com/itm/145010031026
Reply 134 of 467, by supercordo
A 1.5 Willamette arrived today. Was able to increase the FSB. Was only able to beat my old score by 4. I'm sure ill be able to push it further with the P4P800. It seems 3dMark2000 likes more MHz vs FSB.
Reply 135 of 467, by H3nrik V!
supercordo wrote on 2023-11-19, 05:06:
In the name of all that is holy, THAT is a piece of beauty! It's a shame I'm in the EU, though ...
Reply 136 of 467, by H3nrik V!
FSB yanked up to 120, CPU @2160. Tight memory timings, GPU up to 305 MHz, driver setting to fastest. Target 10000 achieved. Funny enough, 3DM2000 responds bad to these settings, giving in the 8500-ballpark ...
What next - try another speed P4 stepping D0 or try to see what an E0 Celery will clock to?
Reply 137 of 467, by H3nrik V!
supercordo wrote on 2023-11-19, 07:56:
What board are you running here?
Reply 138 of 467, by AlessandroB
making a lateral consideration, can the P4 be seen as the P60? Not in terms of architecture because the Pentium continued until 233 but in terms of the uniqueness of the socket/platform? The P4 wasn't there before and will never be there again after its disappearance, right?
Reply 139 of 467, by DerBaum
AlessandroB wrote on 2023-11-19, 11:44:
Desktop Pentium 4 was available on 3 sockets, 423,478,775 .
Probably the most special one is 423 with its small range of processors released and its very short lifetime.
There is a version of socket 423 boards with sd ram instead of RD ram. Thats probably the most exotic version... not good, but exotic.
Or are you speaking about the "long pipeline" thing?
FCKGW-RHQQ2
