First post, by bachler
Hello all.
Anyone know what this motherboard is, or something to point me in the right direction?
I found this in a portable/luggable PC called "IMC TRAVELLER 286"
I found some manuals related to this system here: https://archive.org/details/imc-t-286-lcd-por … age/16/mode/2up
But that motherboard does not seem like the same as mine.
Any help is appreciated.
Mobo:
The attachment mobo.jpg is no longer available
System:
The attachment 2023-11-20_18-36-29_screenshot.png is no longer available
Reply 1 of 2, by megatron-uk
Appears to use a Texas Instruments TACT8222x chipset - closest matches using that chipset on TheRetroWeb are here (there are only two , unfortunately):
https://theretroweb.com/motherboards/?page=1& … &chipsetId=1365
The closest individual match is this 'FTC?' board here:
https://theretroweb.com/motherboards/s/ftc-ver-8.0
There are some slight differences in component placement, but appears to use the same/similar quantity and model of supporting chips, and your BIOS roms are badged as 'FTC' also. I'd be willing to bet that either yours or the one on TRW is a slightly difference revision of the same model.
https://www.target-earth.net
Reply 2 of 2, by evasive
The manual linked in there is for the "VER 8.0" board already listed on TRW. The schema in there literally says "VER 8.0" as well.
I'll have a look if I can find anything that matches layout and jumper names for your board.
