Aztech Sound Galaxy cards
Reply 180 of 189, by Tiido
That card uses National Semi's fliter chips and those are very noisy. I bypassed the one on my BXII card and it became nearly silent as far as that hiss goes.
Reply 181 of 189, by Ozzuneoj
Tiido wrote on 2023-11-21, 12:44:
Sorry, I know this is an old post, but can you explain how you did this and if there are any downsides to doing so? Thank you!
Reply 182 of 189, by Tiido
You'll have to look at the datasheets to identify the input and output pins, then separate them and run a wire across in the most simplest way. Ideally you skip one of the DC blocking capacitors too, doesn't matter if the input or the output one, as long as you don't have both of them since that just will end up reducing low freq response.
As far as potential drawbacks go, low sample rates will have more aliasing noise which some think is a bad thing, some others such as myself think it is fine and makes stuff sound crisper and not so muffled even if there's a metallic or robotic quality to the sound. Sort of like the debate about filters in SB clones vs none (and I'm in the none camp 🤣).
The card is in my Toshiba T3200, sort of integrated into it so that machine's PC speaker sounds come through the audio output of the card (and also go into the internal speaker of the luggable) so I cannot easily extract it to at least show photos of what I did. It has been a while since I worked on it in any capacity...
Reply 183 of 189, by Ozzuneoj
Tiido wrote on 2024-12-22, 04:42:
Thanks for the input!
Just to get me started on the right path, which chip would probably be the one to bypass on a card like this?
The attachment SGBXII.jpg is no longer available
I will look up the datasheet of course, but I don't know enough about audio circuits to be able to just look at it and know which chip is the offending filter.
(Sorry, this is a picture I took years ago... I just realized the text on the chips isn't very clear. The picture here is much much clearer.)
Reply 184 of 189, by Tiido
The filter chip is the DIP8 with vertical stripe and "MF 4CN-100" written on it. https://www.digchip.com/datasheets/parts/data … eet/321/MF4.php
Reply 185 of 189, by Ozzuneoj
Tiido wrote on 2024-12-22, 05:53:
Great, thank you!
I would obviously check all of these traces up-close first in case there is anything that isn't visible in this picture, but is this the basic idea, with the cyan line indicating the wire I would use to bypass the filter and the input DC blocking cap?
The attachment SGBXII_bypass_noisyfilter.jpg is no longer available
Reply 186 of 189, by Tiido
The output of the chip has to be separated from everything since it is where all the noise comes from, even if it is receiving no input. The input should also be separated since it likely gets influenced due to way it operates.
The DC blocking cap is identified correctly, you'll want to remove it, and connect the hole that goes to input on the chip to ground so that there is nothing for the chip to work with so to speak. The other hole you leave the capacitor in with one leg in air and that one you'll use to connect wire to, which will go to wherever the output DC blocking capacitor is, but the pin that is toward rest of the circuitry and not one connecting to the chip output. I'm not totally sure which of the capacitors is the output one and what other parts there may be that should get removed in the process.
EDIT: Hold up, I got the card out my T3200 and I'll have photos etc. to show what I did to it soon ~
EDIT2 :
* I moved R42 to where C35 is, this separates the input and grounds it so the chip has nothing to work with
* I removed R38 and C29, which separates the filter output.
* I made a bridge with a resistor leg clipping to connect audio out from Aztech chip to its input, bypassing the filter chip in the process.
The attachment BXIImod0.jpg is no longer available
The attachment BXIImod1.jpg is no longer available
Reply 187 of 189, by Siran
My two Sound Galaxy cards
Sound Galaxy BX (sadly don't have the little passive speakers that came with the card)
The attachment 20230602_105710.jpg is no longer available
The attachment Sound Galaxy BX.jpg is no longer available
Sound Galaxy NX II / CPS Soundblaster 2.5 / HighScreen Blaster 3.0
The attachment 20230416_113151.jpg is no longer available
The attachment Highscreen Blaster 3.0.jpg is no longer available
Bonus - Sound Galaxy Wave Power / Escom Wave Power (gave that one away though along with the SB16):
The attachment 20230327_132426.jpg is no longer available
Reply 188 of 189, by Tommyboy_03
I need help to find driver for my aztec clone could somone help me
Reply 189 of 189, by Ydee
Tommyboy_03 wrote on 2025-08-30, 13:31:
Which one?
Some are here: https://dosdays.co.uk/topics/Manufacturers/az … h_downloads.php or here: http://files.mpoli.fi/hardware/SOUND/AZTECH/ and https://www.soundcard-drivers.com/companies/152.htm
But you need to know, which chip AZT (2316, 2320 etc.) you have.
