OSSC output ratios?
First post, by arncht
hi,
i am new at ossc, and i would like to use for dos modes.
could somebody explain, if it is an integer multiplier, and not scaler - how does it possible, eg for 400p:
* output 2x is 1280x800 (how expected): 16:10 ratio
* output 3x is 1600x1200: 4:3 ratio
or if it is possible to do the 4:3 with 3x, how could i do the same with 2x?
sure, the 4:3 would be preferable, anyway i stuck again with some old school display, which supports 4:3 ratio.
Overdoze of the demoscene
