First post, by mtest001
Hello all,
I have an annoying problem on my P200@225 build running on Windows 98 SE: GlQuake works beautifully at 640x480 or even 800x600 in window mode, but I can get it to work in full-screen.
When trying to launch it full-screen the loading process is extremely slow, there are various screen colours and artefacts showing and then right before showing the game demo it crashes silently and drops me back to Windows with no error message.
My GPU is a 3dfx Banshee and I am running the Evolution drivers. I have Quake 1.06, GlQuake 0.97, using Glide and not miniGL (I'm no expert, but there is no opengl32.dll in the Quake folder).
I tried various options such as disabling triple buffering etc but nothing works.
The most frustrating part is that in window mode the game is super fluid.
Thanks for your help.
/me love my P200MMX@225 Mhz + Voodoo Banshee + SB32 PnP + Sound Canvas SC-55ST = unlimited joy !
Reply 1 of 3, by leileilol
mtest001 wrote on 2023-11-22, 16:04:
You're using OpenGL by that point, GLQuake will attempt to use the system ICD (which would be 3dfxogl.dll on Banshee) if there is no minigl provided. and since it's a third-party driver, that ICD's probably some compiled 'mesafx' thing that might have problems
There's also sometimes problems with GLQuake defaulting to 640x400 fullscreen which can cause problems with some drivers so you should specify a res at least. Also make sure it's 16-bit color
Reply 2 of 3, by mtest001
leileilol wrote on 2023-11-23, 01:21:
Thank you for the feedback. So if I understood you well I should try different versions of the 3dfxogl.dll and see how it goes?
I am still not sure to understand what is the difference between running the game windowed and full-screen. Are there different 3D API involved?
Also I'll try out the Darkplaces engine, maybe that will solve my problem.
Reply 3 of 3, by mtest001
FInally managed to find a solution thanks to a redditor... After forcing the color depth with "-bpp 32" AND enabling the miniGL driver the game now works fine @ 1024x768.
I am super happy.
Btw on my setup I am getting around 30 fps @1024x768 and 40 fps @800x600.
