First post, by Shadic95
- Newbie
Greetings,
A project of mine at this time is to Digitally record all of the music from Monolith Production's Claw, on my Sound Blaster AWE32, with the 4MB Soundfont the game loads if you have enough RAM, and with the proper driver to ensure MIDI doesn't sound broken, as newer drivers break MIDI playback (see here: https://twitter.com/lebrickster/status/1728301061708882010 ). However, I am currently having to record these songs from within the game itself, in order to have the proper Reverb and Chorus values, since the game seems to set its own (A global one for all songs, I assume, and not on a per song basis), which are otherwise just the default settings, if I were to play the songs back within WinAmp.
Is there any way to extract the Reverb and Chorus Values and Types the game is setting, so I could manually set these within the AWE Control Panel within Windows, to record these songs without the stutter that also running the game brings? And would there be an easy way to reset the control panel values back to default, after the fact? Thank you!
