First post, by douglar
I have a Radeon 9800 repair project.
Looks like the board is missing a Falco 2.2uH, 20% Inductor. I thought I could replace it with a SIBBLE 2.2UH CDRH104R Surface Mount Power Inductor.
But when I looked closer, it looks like there is resistor underneath it that is missing, R1563o.
Can anyone help me ID the possible missing resistor?
663.75 KiB
1.09 MiB
Reply 1 of 6, by paradigital
Surely it was impossible for that resistor to have existed AND a flush surface mount inductor present as well?
Likely a PCB that was also used for another Radeon product where the resistor existed but the inductor didn’t.
Reply 2 of 6, by douglar
paradigital wrote on 2023-12-06, 18:28:
OK, thanks. The remaining inductor is flush with the board, so what you are saying makes sense.
Reply 3 of 6, by Robbbert
A resistor in parallel with an inductor is used to reduce ringing in the circuit (a kind of parasitic oscillation when a voltage suddenly changes).
You really need to look at another 9800 to make sure what should be there.
Reply 4 of 6, by douglar
The solder pads for that hidden resistor on my board look like they are unused.
I think shevalier might have the same card. can you look at the card from the edge to see if there is a resistor under the I1 inductor?
shevalier wrote on 2023-03-11, 16:22:
Reply 6 of 6, by douglar
Rwolf wrote on 2023-12-08, 01:12:
Zooming in, it looks to me there could be a copper trace between the resistor pads - if so, it should not be mounted.
I mounted the inductor without the resistor, powered up and I got a vga image! Yeah! but the fan was not running.
I powered down after about 15 seconds to fiddle with the fan, and couldn't get an image again when I gave it power again. Booo!
I'll get back to this projects after I finish blowing the tantalum capacitors off an 16K-64K 5150 motherboard. Terrifying little fire crackers, them yellow buggers are!
