First post, by Jackhead
I have a windows98SE System that are working with a voodoo output VGA to a CRT.
Now i want switching to a TFT/LCD solution and get the problem that when i booting into windows the VGA Signal get lost.
I can boot safemode and i got a picture. I testet another cable and TFT same problem.
First i was thinking that have something todo with wrong resolution so back on a crt booting into windows and switching the resolution turn Frequenz to 60Hz.
But again no VGA Signal when i try booting into windows.??
Reply 1 of 7, by DerBaum
Does the tft show "out or range" or something like that ? ... Or does it act like there is really no signal?
FCKGW-RHQQ2
Reply 2 of 7, by Jackhead
It goes to "no signal". I dont get why my CRT works and any TFT dont.
Reply 3 of 7, by ElectroSoldier
Not even the BIOS screen shows on a TFT?
Reply 4 of 7, by Jackhead
it after the win98 splash screen so i assume its from the os switching something wrong
Reply 5 of 7, by giantclam
Model of TFT?
Reply 6 of 7, by Horun
Yes need model of the LCD. Ok so set at 60hz....And what resolution do you have it set at ? Try 800x600.
Reply 7 of 7, by rasz_pl
Might have something to do with https://en.wikipedia.org/wiki/Display_Data_Channel Video card might fail to detect any monitor and shuts down output? What monitor do you have configured in win98? I suggest you delete it or force generic nonPnP VGA one.
