Reply 20 of 37, by iraito
- Oldbie
Thermalwrong wrote on 2023-12-15, 21:51:Well if it is a driver problem then you should still be able to run tomb3dem from DOS.
Going from Voodoo 2 to Voodoo 1 on my win98se test install required doing this: Uninstalling the Voodoo 2 driver, manually clearing all files in the Windows directory that match the files in the V2 driver folder, clearing all 3Dfx registry entries, helped in my case. Then the Voodoo 1 drivers could be reinstalled and they no longer caused a crash. Alternatively just reinstall Windows
Before doing that can you point the registry entries? i want to try and clean things up.
If you wanna check a blue ball playing retro PC games
MIDI Devices: RA-50 (modded to MT-32) SC-55
