First post, by BEEN_Nath_58
While testing my GTX 1050Ti on CGA, EGA, TGA, the games just blacked out. No colour whatsoever. However VGA modes worked fine, as well as VESA mode in Duke Nukem 3D.
How's the color compatibility in the last generation cards, and the RTX cards?
Reply 1 of 8, by PD2JK
Last gen cards dont have VGA or DVI-I/A, so it wouldn't make sense to implement old tech like RAMDAC or support for CRTs.
Does your 1050 have any analog output?
has all kinds of stuff
Reply 2 of 8, by BEEN_Nath_58
PD2JK wrote on 2023-12-13, 15:41:
Only a dual link dvi-d
Reply 3 of 8, by The Serpent Rider
Last Nvidia card with analog support is 980 Ti/Titan X Maxwell
Reply 4 of 8, by BEEN_Nath_58
The Serpent Rider wrote on 2023-12-16, 12:16:
Hmm that looks like it. Since 10 series it has all been DVI-D only. Also the VGA/DVI-I output on those cards were pretty broken anyway...
Btw why is VGA/SVGA/MONOCHROME still available on HDMI?
Reply 5 of 8, by darry
BEEN_Nath_58 wrote on 2023-12-16, 22:54:
Backward compatibility is required for things like booting in legacy BIOS mode.
Some legacy commercial and industrial applications still might need to run from DOS (and other OSes), for example, and talk to a VGA compatible card directly, regardlessof the type of monitor connected to it. Prior to native analogue RGBHV being removed from cards, VGA compatibility typically worked on DVI/HDMI and analogue RGBHV output. Removing that VGA functionality would have made those essentially cards useless when booted in BIOS legacy mode (or on a UEFI motherboard when using CSM).
Cards that only support UEFI booting (no CSM) have no reason to support VGA hardware compatility (nor would they have a practical way to do it, as executing a legacy VGA BIOS would be required, and this cannot run on UEFI motherboards that do not have CSM support).
Reply 6 of 8, by beeper6581
For many years I've found that Intel integrated graphics on laptops or motherboards has had way better support for old video modes than Nvidia/AMD/ATI.
Reply 7 of 8, by BEEN_Nath_58
beeper6581 wrote on 2023-12-17, 19:59:
Don't know about ATI. But at least for the last 10-15yrs that seems to be the case
Reply 8 of 8, by darry
BEEN_Nath_58 wrote on 2023-12-17, 20:16:
Ironically, Intel iGPU graphics were among the first (if not the first) to completely drop support for VGA compatibility through CSM .
