Reply 26220 of 27574, by Horun
Digging thru some "dead" parts found a bios chip for ECS P5VX-BE with bios 1.4. Noted there is not a lot on that board so wasted a few hours digging around and got a few more bios, the manual and a FAQ.
Upped to our library and archive org. http://www.vogonsdrivers.com/getfile.php?file … 132&menustate=0 and https://archive.org/details/ecs-p-5-vx-be-stuff.-7z
Noticed that TRW has the board but no manual or bios. Maybe they can add the extra info.....
Also found minor stuff to ECS P5VX-A and P5VX-B but incomplete so far... just rambling. 🤣
Reply 26222 of 27574, by Horun
darry wrote on 2023-12-18, 05:41:
Rippin' through my audio CD backlog (hope that's retro enough)
As long as the music is from before 1995 it is 😁
Reply 26223 of 27574, by Ensign Nemo
Horun wrote on 2023-12-19, 03:10:
And only if it is one of those hybrid CDs with multimedia that can be viewed on an old PC (-:
Reply 26224 of 27574, by Shponglefan
Still trying to get a working Pentium Pro / Windows 95 build going...
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 26225 of 27574, by darry
A lot of it is .
The soundtrack to Freejack (have not seen this since my last VHS rental of it) and a compilation of Erik Satie's most memorable works spring to mind.
The latter was a challenge even for my go-to Plextor drive .
Disk rot, to the last, I will grapple with thee... from Hell's heart, I stab at thee! For hate's sake, I spit my last breath at thee! 😉
Reply 26226 of 27574, by Ensign Nemo
darry wrote on 2023-12-20, 07:35:
A lot of it is . […]
A lot of it is .
What software are you using? Have you tried Exact Audio Copy?
Reply 26227 of 27574, by Shponglefan
Needed to figure out a way to attach a Noctua 60mm fan to a Pentium Pro heatsink.
225.41 KiB
Started by gluing some screws onto the fan to act as attachment points.
132.96 KiB
Then I used these rubber grommets to affix the screws to the metal fins on the heatsink.
136.41 KiB
Since the fins expand in width towards the base of the heatsink, sliding the grommets down tightens their grip. Since the screws have ridges, it prevents the grommets from sliding back up. End result is quite sturdy.
233.38 KiB
Reply 26228 of 27574, by PcBytes
Somewhat ghetto fixed an Luckytech P6BX2 and it POSTs so far.
Reply 26229 of 27574, by Kahenraz
Shponglefan wrote on 2023-12-20, 22:36:
This is rather ingenious. My go-to method has been aluminum tape, doubly secured with an additional layer of gaffer tape, or sometimes one or the other, depending on the need.
Reply 26230 of 27574, by Shponglefan
Kahenraz wrote on 2023-12-21, 01:15:
Thank you, I will admit I stumbled on this purely by accident. 😁
Out of curiosity, do you have a picture of how you tape a fan to a heatsink? I'd be concerned about having enough adhesion on the fins without blocking the heatsink itself, so I'm curious how you've gone about it.
Reply 26231 of 27574, by darry
Ensign Nemo wrote on 2023-12-20, 07:41:
A lot of it is .
I use DBPoweramp. the metadata source integration, the ease with which it is is configurable (great interface) and the flexibility have made me a happy DBPoweramp aficionado since about 2012. Money well spent (on initial purchase and later upgraded versions), IMHO.
EAC does work well, but it is not as seamless and easy to configure as DBpoweramp.
Reply 26232 of 27574, by PD2JK
Troubleshooting an Asus CUBX-E, it won't power on.
When forcing the power supply to be turned on with the green and black wire, the northbridge warms up. The CPU doesn't.
After measuring all the FETs, one in particular doesn't have a Gate voltage. Maybe this one is dead Jim.
1.72 MiB
Reply 26233 of 27574, by blakespot
I got up to trying to find some Xmas songs for the TNDY Tracker (Tandy 1000 tracker) or Apple II 8-bit version of Music Construction Set -- to no avail.
bp
:: Visit the Byte Cellar, my vintage computer blog (since 2004).
:: See a panorama of my own Byte Cellar (a.k.a. basement computer room)...
:: twitter: @blakespot
Reply 26234 of 27574, by H3nrik V!
Trying to learn anything SCSI related: Adaptec AHA-2940U and Quantum Atlas IV
And also effed up an 8.4 GiB Samsung IDE drive, as I accidently had the Molex connector the wrong way [D'Oh] - it had contact enough to make it smell smoky, and after correct polarization, it was very evident that the magic smoke was leaving one of the big ICs 🙁
    462.02 KiB
    Where the smoke left ...
Reply 26235 of 27574, by PcBytes
PD2JK wrote on 2023-12-21, 17:12:
Troubleshooting an Asus CUBX-E, it won't power on. […]
Likely dead. I suppose a replacement should get it running - old boards were rather tough in regards of MOSFET stuff.
Reply 26236 of 27574, by Shponglefan
That's an inconvenient location for desoldering. 😒
Reply 26238 of 27574, by PD2JK
Shponglefan wrote on 2023-12-21, 19:12:
Yeah this one is gonna need a few layers of aluminum tape to protect the socket and the ATX connector.
Maybe I can find a donor board with an appropriate MOSFET.
Reply 26239 of 27574, by H3nrik V!
dormcat wrote on 2023-12-21, 19:53:
H3nrik V! wrote on 2023-12-21, 18:45:
Just curious: how was it achieved?
Apparently the pins on the power supply was close enough to the edge of the insulation to make contact with the pins of the drive - probably because I was being clumsy down at the floor ...
And the fact that it is a modern psu with all black wires, so I didn't have any visual help, maybe added to it?
Furthermore it seems that the incident also killed my external USB to 3.5/2.5 IDE and SATA converter. It smells "technical" and drives, that used to enumerate on it, doesn't ... 😕
