First post, by Duffman
I was wondering if anyone knows if there a way to easily switch between VXD drivers and WDM drivers?
I ask because Daemon Tools does not work well with CD Audio and VXD drivers, games like GTA1 won't play CD Audio in a DOS window unless you use WDM drivers.
My sound card is a CMI8738, it has both VXD and WDM drivers.
I tried creating a 2nd hardware configuration in device manager and installed the WDM drivers on it, but the changes applied to both configurations.
Uninstalling and reinstalling the sound card drivers every time I want to switch isn't ideal.
So does anyone have any ideas for how I could do this?
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 1 of 4, by elszgensa
There's always the option of having two entirely separate Windows installations. Might be overkill and a bit time consuming to set up, but it's simple and proven to work. Bonus, the games that require setup A to work won't even show up in setup B, and vice versa.
Reply 3 of 4, by Duffman
@elszgensa
Whilst that would work it is a bit of a hassle to setup as you said.
A last resort if nothing else works.
@Tiido
I tried the options in device manager, but after switching to WDM drivers the changes carried over to both configurations.
Maybe I didn't do it right? How do hardware profiles work?
CPU: Ryzen 9 5950X
Reply 4 of 4, by Tiido
I don't actually know for sure if they are the solution, I messed with them briefly in past and I think I managed to make a similar setup work. It is possible the WDM driver purposefully tries to find and change conf of any existing VXD installation it is compatble with, so maybe now after you do VXD on one, things settle.
