Win 3.11 networking
First post, by Aokiji
Good day gents
Been having a problem with my 486 dx2 66 always had win95 on it worked great be it wuite slow and i do t really need 95 for any type of gaming.
On my 3.11 got a ne2000 compatible with c
Tcpip protocol on seems to be working a sense.
Problem is its refusing to get a dhcp lease it gets offered by my dhcp server but the system does not take it .
Have tried other ne2000 drivers as well with same result anyone have a hint/solution to point me in the right direction
Got dos 7.1 installed
Reply 1 of 6, by Disruptor
Is it working with static IP?
Just to ensure you have no IRQ problem...
Reply 2 of 6, by Aokiji
No configured as dhcp tried static with dame result though
Reply 3 of 6, by Disruptor
If you don't get any ping with TCP/IP it either may be wrong selected cable type (BNC=COAX=RG58/AUI=DB9/TP=RJ45) or wrong IRQ.
Use the card's jumpers or configuration tool.
Reply 4 of 6, by progman.exe
Aokiji wrote on 2024-01-01, 15:51:
How do you know this? A lease appearing on the server? Or more hardcore, watching the DHCP traffic?
The tests I'd do are:
ping 127.0.0.1
ping localhost
If these work, TCPIP should be installed properly.
If you give a static IP to the NIC (eg 192.168.1.2), can you then ping that IP from the same computer? You should be able to. If not, then there is probably a problem with the card, or drivers.
One thing I suspect is the DHCP server is new, the DHCP client old, and subtle changes with time have piled up.
From stuff on my home LAN, modern DHCP clients seem to use some kind of UUID to identify themselves, not just the MAC. I had to change my DHCP server to force it do things the older way, using just a MAC to differentiate computers. Your DHCP server might be saying something to the DOS client that it doesn't understand, so just sits there, not setting you up the internets 😀
Reply 5 of 6, by Robbbert
The usual problem with WFW is wrong drivers, like they said. I never use DHCP for my computers, everything has static info, filed into a spreadsheet.
To test the IP address I usually ping my main router or 127.0.0.1 .
Reply 6 of 6, by Jo22
Oldwr network cards have configuration programs for DOS.
So the boot socket, transceiver type, resources etc can be set.
That might still be needed for WfW 3.11, too.
While WfW has auto detection for NICs, it doesn't automagically configure everything on its own.
It rather assumes that the NIC is ready to go.
Edit: I never had trouble with DHCP of the TCP/IP-32 network stack.
I just made sure the sub net mask was correctly set.
