First post, by Snocksman
Hi !
I build up a nice 486 VLB System (DX4-100 with 64MB of Memory) and I´m trying to get Dune II running with digital samples (speech in the Intro and so on...). But if I run the setup it tells me every time, that there is no extended memory available, but I configured the System for XMS and I have 615K of conventional memory free (should be enough, I think...). Does the game have any issues with the 64MB Memory in my system... Maybe can´t detect it because it´s too much ?
The attachment IMG20231231011650.jpg is no longer available
Reply 1 of 14, by BloodyCactus
dune wants like 16mb xms, it has a bug that it cant detect over that much and it goes negative.
Reply 2 of 14, by Snocksman
OK, I allready expected something like that. Is there a patch, or workaround for this problem ?
Reply 3 of 14, by Rwolf
Allocate a large ramdrive perhaps?
Reply 5 of 14, by Dusko
Or... you can try removing ram from the computer. I have 16mb of ram and have no problems running Dune II, and as far as I know 8mb is more than enough for DOS.
Retro PC games channel: http://www.youtube.com/@myRetroPC
Electronics, mods and tools channel: https://www.youtube.com/@RetroRust-75
Reddit: https://www.reddit.com/r/MyRetroPC
FaceBook: https://www.facebook.com/myretropc
Reply 6 of 14, by Snocksman
OK, I managed bringing my expansion Memory down to 16MB using RAMDRIVE (two RAM Drives, 1x32MB and 1x16MB) . Now the Setup is fine with the expansion memory, but I still have a problem... I want to play the game in german language. The ingame voices are ok and speak german, but there is no speech in the Intro. If I set the game to english language, the speech in the Intro is there, but in german it is not.
Reply 7 of 14, by Rwolf
There does not seem to be an original intro audio in German, your best bet is to use subtitles for this.
There was also a clone of this game made, called 'Dune Legacy', which used the original sound files, but there was no German intro listed among those files either.
I did find a home-made German intro audio on Youtube, but it sounded a bit too corny for my taste. Only suggested if you cannot use subtitles at all:
https://www.youtube.com/watch?v=uJmo0ZMwb8I
Reply 8 of 14, by Snocksman
I know, back in the days, I had a version with german speech in the Intro... It was spoken by a male voice... A bit loveless, the english version was far better...(not so bad as in the Video you linked to )
Could it be that this Intro voice was not "original" made by Westwood ? Maybe a fanmade Version ?
Reply 9 of 14, by Kalle
I have the CD version of Dune II and there is no german speech in the intro. Maybe you're mixing it up with Dune 2000, which was localized to German entirely? Though Dune 2K had a female narrator (except for the emperor's lines). Or indeed a fanmade version, though in the 90s they would have been hard to come by.
Reply 10 of 14, by Snocksman
No, it was Dune 2... Not Dune 2000. I remenber the first Part with "Land of Sand", which sounded a bit Strange in german... "Land aus Sand".
I think, then it really was a fanmade Soundfile...
Reply 11 of 14, by keropi
Frank Umberto's Ramdisk package is probably the best solution for such situations:
- it can be loaded/unloaded via command line
- with the /t switch it will occupy memory above the 16mb limit so software that has such issues will run fine (Realms of Arkania 2 for example)
- no need to experiment with other memory drivers/providers
http://www.geocities.ws/politalk/rmdrv/fu_rd19i.htm
Reply 12 of 14, by Snocksman
Hey, thats a good Tool, thanks ! I allready thought how I should implement the solution with ramdrive... (Bootmenu in config.sys...) But this one seems to be much better. So i can put a batch in the game directory, in which i load the ramdisk, start the game and unload the ramdisk when quitting the game. Cool !
Reply 13 of 14, by keropi
Snocksman wrote on 2023-12-31, 17:40:
[...] So i can put a batch in the game directory, in which i load the ramdisk, start the game and unload the ramdisk when quitting the game. Cool !
exactly!
some like this will work fine:
XMSDSK 55000 /y /t
GAME.EXE
XMSDSK /u /y
it will use 55mb of XMS for ramdisk, launch game and on exit it will unload ramdisk
Reply 14 of 14, by Snocksman
Ok, I have tested the xmsdsk program in a run.bat file for Dune 2. Works as supposed. Very nice !
