Reply 100 of 112, by 386SX
This card was made by Diamond. I've used a Viper 550 (TNT) for years and a friend of mine used a Viper 770 (TNT2) for years also […]
This card was made by Diamond. I've used a Viper 550 (TNT) for years and a friend of mine used a Viper 770 (TNT2) for years also. Both were passively cooled and seemed to at least not have too much serious thermal issues.
But about your worry about frying your Viper 2: If you rig a fan to the heatsink like in the link I provided (you could also opt to use better case ventilation if you prefer that over rigging active cooling on your old graphics cards) then you should be home free, so to say 😜
And the way Brostenen rigged his Voodoo 3 is actually quite popular here on Vogons, for several for good reasons:
-It's cheap
-It doesn't damage the card (no damaging the original heatsink...if you care about that 😜 but lots of people prefer to not ruin the original heatsink, including me)
-It's very fast and very easy to do, only need some wires and at least some common sense
-Most important is...it works! 😁 I modded my GF6800 (Vanilla Edition) the same way, only had to remove it's original fan assemblySo I can highly recommend it 😉 Only thing that could go wrong I think is if you have some accident while rigging the fan, like ESD damage for instance.
Running this Athlon Tbird 1000 with Viper II Z200 right now and posting with latest S3 drivers. It doesn't have the controls of the original brand drivers but seems to be lighter and simpler to install.
Running with the jumpers opened until I understand if actually all of them must be closed for AGP 4X. I got ~2200 in 3dmark2000, is it right?
