First post, by envagyok
For 1995-1996, I'm putting together a spec P166 PC with an ASUS P/I-P55T2P4 motherboard, 512k cache, 64MB RAM, and I'm going to put my proprietary API cards in it, e.g. Nvidia NV1, Matrox millennium, ATI 3D Rage, Matrox Mystique, Rendition verite, and if i later find, then Powervr, matrox impression, 3d blaster, etc.
I'm thinking about what sound card good to put in this PC, what is "different" than the usual Creative AWE32-64-SBLive line, i have with these many config already.
The Vortex chip cards are not yet up to date, neither is SBLive, AudioPCI is a bit younger, and I don't know what their sound quality is like.
What i have:
- SoundScape VIVO
- Miro miroSOUND PCM12
- Yamaha Sound Edge
- Terratec EWS XXL
- Terratec Maestro 16/96
- ESS 1868
- OPti MAD16
- Addonics Yamaha Audician 32
- Yamaha Waveforce 192XG
- Gravis Ultrasound PnP
I also have a Yamaha SW60 midi card, and I have Yamaha DB50XG and Roland SCB-55 daughterboards, as well as Gravis ACE.
I don't know which audio format is best suited for games from 1995-1996-1997, and which of these sound cards will output it best.
This period of time seems a bit of a no-man's land to me, DOS slowly dead, but no eax, a3d.
Reply 1 of 9, by Joseph_Joestar
envagyok wrote on 2024-01-16, 20:10:
My vote goes to the Yamaha Waveforce 192XG. It has pretty good DOS compatibility for a PCI sound card, provided that your motherboard supports either DDMA or SB-Link. Its Yamaha XG MIDI sounds excellent, and you get genuine OPL3 for older DOS games as well.
Because it uses Sensaura technology, A3D 1.0 and EAX 1.0 are also supported. Although not super common, some 1997 games did eventually get A3D support via later patches. Dark Forces 2 is one such example.
My retro stuff
Reply 2 of 9, by chinny22
This whole era was a mess (which is what makes it interesting now) and you'll spend just as much time in dos as you will windows.
Plenty of games no longer used midi but plenty still did so would pick something with good sounding midi.
I can't think of any games in the 3d proprietary API list that use EAX or A3D but seems sensible to have it covered just in case so would go with the suggestion above.
Reply 3 of 9, by Shponglefan
1995 to 1996 is still a heavy DOS gaming period. Windows gaming didn't really start dominating until 1997.
For mid 90s DOS gaming, I always go with an SB Pro-compatible + GUS + Roland combo. FM synthesis is generally less important by this stage, since most gaming music was either General MIDI, tracker based, or CD audio.
My own preferred DOS gaming soundcard combo is the GUS Extreme + Roland SCC-1. In your case, I'd go with the ESS 1868 + Roland daughterboard + GUS ACE. It would basically recreate the same setup.
Then for Windows you could include something like the Yamaha Waveforce 192XG, since it has native Windows 95 / DirectX compatibility.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 4 of 9, by envagyok
Here's the list of games with support 3d proprietary API-s :
I have already 2 build for DOS/Windows95 gaming:
P1 233MMX/Diamond S3Virge+Diamond 3dfx Voodoo1+Gravis Ultrasound+Awe32 CT3900+Soundblaster PRO2+SC-55+MU50 is for w95/DOS
486DX2-66+VLB Graphics+Soundblaster Pro+MT-32+FB-01 for older DOS games.
I need the third rig only for use with the games listed above utilise the advantage of pre directx/glide graphics card for better picture quality or/and speed.
Reply 5 of 9, by qdsong88@
Joseph_Joestar wrote on 2024-01-16, 20:18:
Waveforce 192XG is very good, I have used it for a long time, but have never tried it for DOS games.
C300A / E2140 / E3-1230 V2
K6-2 / Athlon X2 5000 / Ryzen 7 1700
Reply 6 of 9, by leileilol
Waveforce is the card that's most strikingly appropriate when glancing that list. Some of the cards are too 1994core (MAD16 should never be a choice for a system like this and it's had trouble with Directsound compatibility in the DX2/3 days)
Reply 7 of 9, by envagyok
Yamaha waveforce compatible with Games running under DOS?
For example: Tomb Raider
Reply 8 of 9, by Joseph_Joestar
envagyok wrote on 2024-01-17, 23:28:
Yes, it has SBPro compatibility for DOS games.
Phil reviewed a similar card in this video.
My retro stuff
Reply 9 of 9, by envagyok
I change the motherboard to Socket 5 because i have many socket 7 build already.
With Pentium overdrive 166mmx cpu, and Intel advanced/zp zappa board with mr. bios
So i dont have sblink connector, then i cant use waveforce xg (and its too young for this config)
What is the best solution from list above for 1995-1997 properiarty api games?
