First post, by ancanar
Hello
I want to buy JK2 from gog but I read that there are problems with running the game on Windows 10. Do You know of any sure way to make it work on this system? Or is using a machine with Windows 7 the only way to play it?
Thank you in advance for help
Reply 1 of 13, by TheAbandonwareGuy
What issue are you having specifically? Is it just closing as soon as you open the game? Try running it as admin in Windows 7 compatibility mode.
I know for a fact that Jedi Academy runs fine on Windows 10 as I play it regularly, JAMP is literally a direct engine upgrade of JKII so I have no idea why it wouldn't work.
Reply 3 of 13, by ancanar
TheAbandonwareGuy wrote on 2023-04-02, 15:39:
No issue yet as i did not buy it but while GOG states that Jedi Academy is compatible win windows from vista to 10 with Jedi Outcast it says only Windows Vista/7/8. Also I read ppl reporting problems on forum
Reply 5 of 13, by leileilol
Pulling an nvidia, AMD's had some OpenGL games regressed from recent drivers that are "faster" with the less sanity checking Vulkan-based ICD reimplementation. Maybe that's it. I know I couldn't start older builds of Quake3 anymore since that update.
Reply 7 of 13, by RetroGamer4Ever
JK2 and it's sequel should work fine on Windows 10. I certainly have no problem running the stock games and you can use the community mod version that gives feature updates to run better on modern systems and GPUs.
Reply 9 of 13, by BEEN_Nath_58
ancanar wrote on 2023-04-02, 19:57:
Any idea about intel cards?
Probably throw dgVoodoo2 at it, considering Intel new drivers are very immature on DirectDraw and old DIrect3D.
Reply 11 of 13, by teleguy
BEEN_Nath_58 wrote on 2023-04-04, 18:41:
It's an OpenGL game so you can't just add dgVoodoo but this (https://sourceforge.net/projects/gldirect/fil … tial%20Release/) should help. You can now also put dgVoodoo on top of it if you want.
I also use this mod for better graphics: https://www.moddb.com/mods/jk2-fx-mod
    bin.zip
    487.5 KiB
    92 downloads
Reply 12 of 13, by BEEN_Nath_58
teleguy wrote on 2023-04-10, 12:24:
You are right. i was thinking about Jedi Knight DF 2
Anothet option here could be Mesa3D renderer
