First post, by Amigaz
- Oldbie
After finally getting my Soundblaster 16's cards working !00% in DOs with drivers etc I've noticed that the sound output is quite low..I have to crack my speaker system up to the max to get a reasonable sound level...
I've fiddled with the mixerset parameters but it doesn't seem to like anything higher than 224 for both channels (master level)
It's a bit better with my SB16 CT1740 which has the volume level adj. wheel at the back.
Any ideas?
