Show me your testbench
First post, by H3nrik V!
Looking for inspiration. As of now, I have a motherboard tray with no support for peripheral cards lying on top of a stack of til boxes. FDD/HDD/ODD lying next to it, power supply falling down often. It sucks, but I'm missing the inspiration to make something smart. Help me out here 😎
Reply 1 of 19, by acl
H3nrik V! wrote on 2024-01-14, 21:22:
I have the cheapest testbench from Amazon with a 939Dual-Sata2, an A64 3200+, a CF to IDE card and a 1000w modular PSU.
No room for hard drives or optical devices either.
The attachment IMG_20240120_114816.jpg is no longer available
Reply 2 of 19, by RandomStranger
It used to be a salvaged motherboard tray and drive bay from an ATX case. In recent times I'm just using a uATX Acer Veriton desktop case.
The attachment IMG_20240120_121345.jpg is no longer available
The attachment IMG_20220313_160937.jpg is no longer available
"Proper" testbenches are way to overpriced for what they are.
Reply 3 of 19, by Shponglefan
My test bench is just the top of my workbench. It's covered in an anti-static mat, so I'm not worried about shorting anything.
I prefer the flexibility of being able to mix and match any components as needed. Especially since I routinely work on both AT and ATX setups.
Just basic board with an ESD surface is really all that's needed for a serviceable test bench, IMHO.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 4 of 19, by H3nrik V!
Nice to see some setups. My problem is space, so I am balancing everything on top of my Milwaukee PackOut til boxes, so I need something that can quickly be removed for me to open the boxes.
I'm currently using an ATX mount plate from a Thermaltake Cube, which I had to scrap since vinegar, sunlight, etc wasn't enough to get the smell of smoking out of the plastic parts. Unfortunately it doesn't have any retention bracket for pci etc., but I'm about designing and 3d printing parts to mount psu, hdd, fdd, odd etc below the plate, hoping to be able to get it stable enough ...
Reply 5 of 19, by H3nrik V!
Oh, BTW, I do have a stack of ATX cases in the shed, I just don't feel right about gutting a perfectly fine case for the tray and drive mounts ..
Reply 6 of 19, by demiurge
acl wrote on 2024-01-20, 10:49:
That looks identical to what I did but I didn't like the fact the PSU only had two screws holding it in. I upgraded to a stacking version for 50 dollars on AliExpress.
Reply 7 of 19, by paradigital
Dimastech test bench here.
The attachment IMG_2849.jpeg is no longer available
Reply 8 of 19, by Pierre32
Modified a balsa crate for my little backplane.
The attachment test bench.png is no longer available
Reply 9 of 19, by Intel486dx33
I purchased this really nice Bench with draws and shelves and power strips.
I purchased from a computer supply liqidator.
It’s in my Garage with boxes stacked on top.
So I never use it.
For now I just use my 486 computer as a table with a cardboard box on top for a Test Bench.
Reply 10 of 19, by demiurge
Yes it is me. I can't reply to PM because of forum rules.
Reply 11 of 19, by nd22
Cooler master haf xb evo can be configured as a test bench, "normal" pc, taken to a lanparty; it's stackable... you name it!
Reply 12 of 19, by H3nrik V!
nd22 wrote on 2024-01-25, 10:31:
Yup, that's the case I have for my daily driver 😀
Reply 13 of 19, by vutt
My reasonably priced one 😀
I got this one I think 6 or so years ago for retro build in mind for 15 EUR brand new. Well I can say it was objectively priced. Still paid for it so I'm using (part) of it.
Reply 14 of 19, by H3nrik V!
vutt wrote on 2024-02-04, 11:54:
I got this one I think 6 or so years ago for retro my build in mind for 15 EUR brand new. Well I can say it was objectively priced. Still paid for it so I'm using (part) of it.
That's a cool take on it 😀
Reply 15 of 19, by H3nrik V!
I've decided; in the light of nothing reasonably priced available, to put the Ender 3v2 and Fusion 360 into work.
I've let myself get inspired by this https://www.thingiverse.com/thing:4935303 and am in the process of constructing a similar setup, using the tray from the ThermalTake as a base, and printing side stands like the ones in the link, with a PSU mount. Also I'm making mounts for 5.25" ODDs, 3½" floppy and whatever number of 3½" HDDs there'll be room for.
Any inputs on what else, I'd be happy to mount underneeth the tray?
Reply 16 of 19, by Shponglefan
Decided to finally build myself a test bench platform. While putting components directly on my workbench was fine, it definitely wasn't optimal for space.
I'm hoping to stack the PSU and drives underneath the motherboard will give me more space to work with.
Reply 17 of 19, by H3nrik V!
Shponglefan wrote on 2024-05-20, 17:07:
Nice work. Wish I had the tools (who am I kidding; the talent) to work on plywood like that.
Reply 18 of 19, by Shponglefan
I finished my test bench. I added a slot on cut-out on top for routing power cables. I found that some PSU cables wouldn't reach, so this solves that issue.
Also added some edgebanding and glued down some anti-static mats. The rubber coating helps grip things in place.
Reply 19 of 19, by Shponglefan
H3nrik V! wrote on 2024-05-20, 19:56:
Thank you! Not sure how much talent is involved, but having a table saw certainly helps! 😅
