First post, by Merrickk
I have a program written in Turbo pascal that I am trying to get working. The program interfaces via serial port to a programming coil that uses magnetic communication to interface with a device that is a hermetically sealed housing. Anyway... I'm told that the app will not work above 33mhz so I am attempting to use DosBox to solve this problem. I feel as if I am also having serial port issues. I have been reading up on this for about 5 hours now, and have tried about everything that has been listed. Attached is my log from the serial debug version of HAL's build. I would appriciate any help you all can give me on this.
Thanks!!!
    dosbox_000.serlog.txt
    20.07 KiB
    383 downloads
Reply 1 of 4, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
I found a bug, don't know if it helps though.
Try this:
http://home.arcor.de/h-a-l-9000/test/dosbox_int14_b.zip
Please add 'dbgaux' to the serial debug config too.
If it doesn't work there's another chance.
1+1=10
