Reply 51540 of 53143, by Shadzilla
eesz34 wrote on 2024-01-23, 14:07:
I did phone tech support for those around the time this one was manufactured. I can't remember if it was that case, but some designs had a problem where the power button didn't correctly push on the actual switch underneath.
Nice! I can well believe that, the mechanism is a bit rubbish. Appears ok on this one though, not tested yet mind you.
No Banshee sadly, it has an onboard 'AGP' Riva 128 chipset with 8MB, and onboard Creative ES1373 Soundblaster-ish sound. A distinctly mid-range system. This is the board - https://theretroweb.com/motherboards/s/intel- … ster,-micro-atx - part 4000431 which through some serious archive.org digging and research here I've managed to find the latest Gateway BIOS image in case it needs an update. Next job is to open up the PSU for a clean and inspection, test that, then see if it fires up. Last used about 18 years ago the owner told me.
Reply 51541 of 53143, by Law212
weedeewee wrote on 2024-01-19, 09:18:
Modicon SA85 https://www.classicautomation.com/Part/am-sa85-000 That indicates Modbus Plus Interface Card, which suggests some i […]
Law212 wrote on 2024-01-18, 17:41:
I found these a while ago. I have no idea about them. Anyone know anything about these? […]
Modicon SA85
That indicates Modbus Plus Interface Card, which suggests some industrial network interface.
https://i.imgur.com/w9ZtAQ6.jpg https://i.imgur.com/Khn7v7M.jpg […]
Veeborg's idea is good. Floppy controller is connected to SYSTEM connector, AT or XT/T1500 connectors go to internal floppy drives and external connector to external device.
Thanks to all who replied .... I've been away for a bit and wasnt able to respond until now. Thanks !
Reply 51542 of 53143, by Meatball
Kahenraz wrote on 2024-01-23, 13:57:
Meatball wrote on 2024-01-23, 13:19:
I obtained one of my ‘grail’ items: […]
Quantum3D Raven
Actually, I’m smitten over just the box artwork; everything else is gravy.
The card, paperback, and discs appear to be unused.
There were one or two games that were hard coded to only work on this card, if I remember correctly. Probably something that was included in the box.
Rush Alcatraz is the game hardcoded for the Raven, which had no other physical release. It's been hacked, though, to work on any card.
Reply 51543 of 53143, by rkurbatov
Mozart 16 soundcard on OTI 601 chip and old-new-in-the-box AT Case.
Need to wait for 2 brand new Socket 5 fans to arraive and my 1995 build is ready to be built.
486: ECS UM486 VLB, 256kb cache, i486 DX2/66, 8MB RAM, Trident TGUI9440AGi VLB 1MB, Pro Audio Spectrum 16, FDD 3.5, ZIP 100 ATA
PII: Asus P2B, Pentium II 400MHz, 512MB RAM, Trident 9750 AGP 4MB, Voodoo2 SLI, MonsterSound MX300
Reply 51544 of 53143, by Shponglefan
Just got this lovely DFI ITOX G7S620-N motherboard. LGA 775, Intel 865G chipset, supports Pentium 4/D processors, and even has a pair of ISA slots.
This one should be fun to experiment with.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 51545 of 53143, by rkurbatov
Shponglefan wrote on 2024-01-25, 01:02:
Just got this lovely DFI ITOX 67S620-N motherboard. LGA 775, Intel 865G chipset, supports Pentium 4/D processors, and even has a pair of ISA slots.
Wow, that's interesting. I remember how my friends, musicians, had some ISA sound card with FX processors on it, rather expensive I suppose. It was hard to upgrade for them in 2002-2003 due to lack of motherboards with ISA bus. This one could be very helpful back then.
Reply 51546 of 53143, by PcBytes
Seagate ST336607LW 36GB SCSI HDD came in today.
Reply 51547 of 53143, by DW12
DW12 wrote on 2024-01-09, 19:37:
Yesterday I've got my first ever retro laptop. It is the Fujitsu-Siemens Amilo-EL 6800: IMG_20240109_195834_HDR.jpg IMG_20240109 […]
Spec-wise it is not special really, but it's in great shape for it's age. Hard drive was not formatted by previous owner (of course...), and from file dates it looks like Windows was never reinstalled on it. Dates range from 2003 up to 2013. There were some games installed on it at some point, I've found directories of Carmageddon TDR 2000, The Settlers IV and Worms World Party. Battery is dead obviously. Now I'll have to restore it to factory defaults.
Specs:
- Intel Celeron 2.0GHz
- 256 MB DDR
- 20 GB hard drive
- Integrated SiS Real256 graphics
Got it for only 15$ shipped.
Yesterday I've got a replacement battery for my Fujitsu laptop. It's incredible that I've managed to get one brand new, it must by one of the last ones out there. Now this Fujitsu is fully functional.
1.38 MiB
1.37 MiB
Btw, I've digged a little in the BIOS rom and found that it contains a microcode for 2,8GHz Celeron too. Theoretically I would be able to upgrade it, however I'm not sure if the power delivery of this laptop would be able to handle higher TDP of that chip. There was never any other variant of this laptop other than the one with 2GHz Celeron AFAIK.
1.29 MiB
818.91 KiB
Reply 51548 of 53143, by Disruptor
PcBytes wrote on 2024-01-25, 15:18:
I have the same one here.
mkarcher and me use it to test and fix old SCSI BIOSes to operate with disks > 8 GB.
Reply 51549 of 53143, by dormcat
Should be "G7S620" instead. 😅
If TRW is correct then this motherboard is THE only one with LGA775 + 865G + AGP 8x + ISA combined. Theoretically it could span from DOS to late XP games.
Reply 51550 of 53143, by GigAHerZ
Got this Toshiba T1200 from local classifieds for just 30€!
Supposedly has an issue somewhere in power circuitry. Wish me luck that the rest of the machine is good.
It does look very nice, though yellowed.
EDIT: I've identified that the machine is working, but the screen is not. It has few horizontal stripes, it's flickering and has a bit of whiny sound which pitch is dependent on contrast knob.
There was one board with transformer behind the lcd panel that had some very suspicious 2 capacitors. I replaced them, but it didn't fix the issue...
Reply 51551 of 53143, by Shponglefan
rkurbatov wrote on 2024-01-25, 13:04:
It's fascinating to me how certain motherboards (esp. industrial ones) retain better backwards compatibility for legacy hardware. These are motherboards that would have likely gone unnoticed by general consumers.
I have another DFI motherboard which is Socket 7/ATX, but has 6 ISA slots and is designed to accommodate full-length cards in each slot.
Reply 51552 of 53143, by Shponglefan
dormcat wrote on 2024-01-25, 17:21:
Good catch! Fixed. 😀
This a unique board for sure then! Glad I was able to find one.
I tested it out and confirmed it does work with native ISA sound cards in DOS. Here it is running Sam n Max under DOS 6.22. No throttling either, this is at a full 3.4 GHz. 😅
Reply 51553 of 53143, by PcBytes
Disruptor wrote on 2024-01-25, 17:12:
Nice. It manages to cancel out the screaming fans over the Coppermines (which I hope to replace with 2x Noctua soon enough) with its "angle grinder" type of sound. (HD Sentinel reports 100% health tho.)
I think I managed to have a few of those "angle grinder" type of drives already - IBM Deskstar 60GXP 20GB, Quantum Atlas 10K II, Ultrastar 4.5GB and Maxtor 5T020H2 are to name a few. The least loud of those is the Maxtor.
Reply 51554 of 53143, by Shagittarius
Except you would be stuck with a late AGP video board. I don't think it would be good enough for a lot of XP games.
If you stuck to using official drivers you'd have to go ATI 9800Pro or Geforce 59xx. Otherwise you'd have to cheat for Win98.
Reply 51555 of 53143, by Shponglefan
Shagittarius wrote on 2024-01-25, 22:28:
I wonder if going dual video cards (AGP + PCI) might get around that.
Maybe use something like a GeForce 7-series for WinXP and a PCI card for Win9x + DOS?
Granted even the GeForce 7-series would be limited compared to a PCI-e card for XP gaming, but should still yield playable frame rates at lower resolutions.
Reply 51556 of 53143, by Shagittarius
Shponglefan wrote on 2024-01-25, 22:59:
I wonder if going dual video cards (AGP + PCI) might get around that. […]
I had a 9800 pro when XP was first released, I don't think even 2 gens later is going to be enough for most late XP games.
Don't get me wrong I think the idea would be fun to attempt. But I would rather have 2 machines than compromise on resolution/framerate for XP games. My XP rig has a 780ti, I want to be able to max everything out.
Reply 51557 of 53143, by Shponglefan
Shagittarius wrote on 2024-01-25, 23:04:
I guess that also depends on how we're defining late XP games?
For stuff released late 2000s to early 2010s, then no, it wouldn't be powerful enough.
But for games into the mid-2000s, it should be okay.
Oh, absolutely agree. I've already got a i7-3770k / 980Ti rig for Window XP. No compromises there. 😁
Reply 51558 of 53143, by Kahenraz
It's also important to take your CPU into consideration as well. I upgraded my video card several times in the 2000s, even up to a GeForce 6800 GT, without realizing that my Pentium 1.4 Ghz (later upgraded to 1.8) was holding everything back. That and my 256MB of RAM made it anemic by Windows XP, but RDRAM was expensive and I decided to hold out for a complete upgrade instead. It was quite torturous by the end.
Although I am bias through the lens of nostalgia, I honestly feel that a 6800 GT is more than enough for a pleasurable XP experience. The benchmarks were unbelievable at release compared to previous generations.
Reply 51559 of 53143, by wirerogue
i found this on ebay and thought it looked interesting.
i can't find many references to this card on the internet or here on vogons.
a new orchid kelvin mpeg vlb.
it has a cirrus logic gd5434 along with a em7000 mpeg-1 decoder all on the same board.
1.26 MiB
1.74 MiB
1.86 MiB
1.56 MiB
