First post, by rolloLG
WC (first one) works fine for me with DOSBox, including MT32 properly configured in the .conf (+ VirtualMidiSynth by Coolsoft).
My only problem is the volume of music/sounds with MT32: quite low.
Is there something that can be done?
ROG-mini-22x13.png SCAR 18 G834JY: i9-13980HX, 32GB DDR5@5600, 4090 laptop 256 bit 16GB, 2560x1600 16:10 G-Sync, NVMe 6GB/s, 8BitDo Arcade Stick, EasySMX X10 controller, ROG Strix Carry Mouse.
Reply 1 of 1, by rolloLG
As a workaround a simple prompt command line:
mixer mt32 200:200
did the trick... but if someone knows better WC and how to adjust volume will be appreciated.
