Reply 40 of 47, by kixs
Can't remember the exact settings as this was tested "years" ago 🤣 Whatever were the settings they were the same for all cards.
I still need to define the default setup. Might even use the 1MB stick after all 😉
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
Reply 41 of 47, by MikeSG
douglar wrote on 2024-02-03, 13:30:
kixs wrote on 2024-02-03, 09:43:
A snippet as I want to redo all the benchmarks... […]
file.php?mode=view&id=184373
Very nice start.
You are using 1/4 ISA divider, yes? Does the screen refresh affect numbers? Are you going to use a 1MB cache stick when you retest?
Fast ISA cards should get around 45FPS in 3DBench with a 1/2 clock divider at 33MHz.
CL-5429 (1997), Trident 8900D-R (1997)
ISA Tridents have no windows acceleration
Reply 42 of 47, by Marco
Thanks.
Strange that gGD5434 benefits a lot from 2mb in windows but not the ATI Mach. Maybe the CL enables kind of interleaving then.
Edit: ah yes it’s from 1 -> 2 mb and the other from 2 -> 4mb
1) VLSI SCAMP 311 | 386SX25@TI486SXLC2-50@63 | 16MB | CL-GD5434 | CT2830| SCC-1 | MT32 | WDC160GB/7200/8MB | Fast-SCSI AHA 1542CF + BlueSCSI v2/15k U320
2) SIS486 | 486DX/2 66(@80) | 32MB | TGUI9440 | LAPC-I
Reply 43 of 47, by Marco
I can provide a small benchmarks accelerator vs. non-accelerator in W95. Quite impressive I'd say especially as conducted on a low end PC. Office95 will make much more fun now 😀
- 386SX/27,5
- WD90c30 vs GD5428. Both at 1024x768x256
Reply 44 of 47, by kixs
Marco wrote on 2024-02-03, 19:57:
Thanks.
Strange that gGD5434 benefits a lot from 2mb in windows but now the ATI Mach. Maybe the CL enables kind of interleaving then
All later chipsets have some sort of interleaving. Mach64 too. Only Mach64 VRAM already has 2MB of memory and with 4MB the interleaving stays at 2-way. So performance doesn't change.
Reply 45 of 47, by lolo799
Marco wrote on 2024-02-01, 09:55:
- Finally there are no (or I couldnt find them) real benchmarks available showing the GDI 2D performance of ISA cards under e.g. W95 via Winbench, Wintach, Wintune oder whatever
Regards
Would this one do?
The attachment 20240204_123756.jpg is no longer available
https://web.archive.org/web/19981207044238/ht … ity/gabench.htm
Reply 46 of 47, by Marco
Looks interesting 👍🏻👍🏻
Reply 47 of 47, by Marco
Another benchmark from me:
On my 386sx I compared the Gd5428 with GD5434 2d win acceleration. Although the tech capabilities are much more advanced on the 5434 the 386sx is holding back any performance increases. Yes in some theoretical thruput yes (maybe due to the 64Bit onboard mappings) but in all real world benches as eg wintach only some slight % to be seen.
