First post, by retropol
I have nice ADAX computer, 486dx2 66, with turbo segment display
in one turbo button position it shows 66 (this is ok)
but in other position it shows 8 (it should be 33 afaik)
but I dont know how to setup that, pls help
125.77 KiB
128.11 KiB
Reply 1 of 11, by root42
Well for starters you could put jumpers on the pin header marked HUN. The three headers are labelled: ONE, TEN, HUN. So they are for the ones, tens and hundreds.
Since the HUN is not yet populated you could take ONE jumper and systematically bridge all pins, always checking what bar lights up and noting that down. Then you can figure out how to make the bars for "3" light up (when turbo is disengaged naturally). Once you have that, you can change the ONE and TEN header to the same configuration. I assume that one half of a header is for turbo, the other is for slow mode. If the split is horizontal or vertical, I don't know...
YouTube and Bonus
Reply 3 of 11, by mdog69
From looking at the picture you posted, and informed by looking at (http://www.minuszerodegrees.net/led_speed_dis … 20-%20GK-01.jpg)...
Look at http://www.minuszerodegrees.net/led_speed_dis … 20-%20GK-01.jpg
On your board, the pinout for HUN, TEN and ONE matches the pinout for ONE on the GK-01 board.
From the current setting of the board, "no link" = segment always off, and "vertical" = segment always on
The two horizontal link positions may be different, but "suck it and see" will see you through.
To switch between 66 and 33 you need 14 jumpers in total.
Do the ONE block first, setting the jumpers as follows
A Will always light (leave unchanged)
B Only light for non-turbo (leave unchanged)
C Will always light (leave unchanged)
D Will always light (leave unchanged)
E Only light for turbo - change this to horizontal
F Only light for turbo - change this
G Will always light (leave unchanged)
Test the board and make sure the left hand digit LEDs match the turbo mode.
If it doesn't work properly, move the links for E and F to the other horizontal position, and try again.
Note that you only need to change the E and F links, and each one only has two possible horizontal positions.
Once you get the left hand digit working, do the middle one - install headers on the TEN block in exactly the same positions as the ONE block.
Leave the HUN block empty - (unless you want to make it display 133 or 166, you can figure that one out for your self!)
Reply 4 of 11, by PARKE
If you happen to be more visually set like I am then this little chart may be helpful.
The three rows on your display have identical orientation which makes things easier because the jumper settings are identical.
122.14 KiB
What I do not understand is how the jumpers set as like in your photo can show 66 and 8. Maybe there is a contact problem and you may have to clean the pins and/or use jumpers with a tight(er) fit to make it work properly.
Reply 5 of 11, by retropol
murugan, mdog69, PARKE you are the best one ever!!! 😀 works perfectly fine, 33 / 66 😁
PARKE, i think logic is oposite - non-turbo is 66, turbo is 33.
56.17 KiB
Reply 6 of 11, by PARKE
The original display wire set was designed in such a way, with 2x3 wires coming from the push button, that you could swap the cables in order to accomodate the design of the motherboard - this was either default Turbo or default non-Turbo which then was controlled by the Turbo button which was either pushed in- or released.
http://www.suntekpc.com/htm-2/power-switch-pu … urbo-3p3c-2.htm
edit
PS If you want yours to work 'the other way around' (I assume) you have to swap the positions of the B, E and F jumpers like you did.
Reply 8 of 11, by Jackhead
I have a K-618 segment display that display normal 33 turbo 100 and i want to change the 100 to 66.
Can anyone help what i have to change? I look at the links but not really see my segment there.
1.34 MiB
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - AMD A5x86 X5 ADZ 133MHz @160MHz - 64MB RAM - CT2230 - GUS ACE - MPU-401 AT - ET4000W32P
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI @ 66MHz PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
Reply 9 of 11, by EddieOne
Jackhead wrote on 2023-02-24, 16:37:
I think I have your solution.
958.71 KiB
Reply 10 of 11, by Vaylo
EddieOne wrote on 2024-02-05, 09:47:
Hi Eddie, I also have the K-618. Could I take advantage of your knowledge and ask how to make the display show 166? Thank you very much in advance.
Reply 11 of 11, by wbahnassi
Do you really want 66 and 33? I checked my DX-2 66 and the Mobo's de-turbo brought it down to ~25MHz actually, so I configured my display as 66 and 25. Try running benchmark tools to see what they estimate for you on de-turbo.
