Reply 20 of 26, by Rebella
- Newbie
ok thanx I'll try to reinstall it
Read & do this: 60 seconds guide to getting your game to run in DOSBox
_________________
thanx, in my case reinstalling the game solved the problem 😉
Enjoy the game - it's still a load of fun! I only played it last week 😀 I haven't had a single problem with it so it should run very well.
Oh, and try Theme Park if you can!
hi
I'm trying to install it on vista 32 and get 'could not write files to directory' error when i try to install. I'm doing the steps exactly as you said above.
Thanks
its writing files to the directory but says that it couldn't. how do i run the game now? I keep getting dos4gw.exe not a valid syntax error?
Strange, works fine for me!
