First post, by envagyok
Hi
I bought a lot hardware, but 3 of them i cannot identify.
Thanks for all helping words!
Hi
The one at the bottom is a Video7 ISA VGA with probably 256K memory. It's one of the cards that officially work in both 8-bit and 16-bit slots
The manual is here https://www.minuszerodegrees.net/manuals/Vide … Users_Guide.pdf
The one on the left is a floppy & SCSI-2 VLB controller made by Abit
Thank you!
For this Abit SCSI controller card where can i find jumper settings?
I try to find the net, but no luck, only one other ABIT card, what i founded.
envagyok wrote on 2024-02-08, 10:04:Thank you!
Don't see any jumper settings for the SC3200V (only the SC3210V; try maybe - https://stason.org/TULARC/pc/hard-disk-floppy … -SCSI-Inte.html )
An old post from '93 lists these as the DOS driver disk for the SC3200V...
...and there also seems to be a set for NT as well...
