First post, by envagyok
I've been reading a lot about Ensoniq AudioPCI sound cards these days.
It seems like a good choice for late DOS and Windows 95 games, but there are a couple of issues:
Ensoniq's driver supports Soundscape and Soundblaster Pro modes, while later Creative removed Soundscape mode and replaced it with Soundblaster 16.
Is it not possible to combine the 2 drivers so that soundscape and soundblaster 16 compatibility remains?
I also read that the OPL3 emulation is of poor quality.
Is it not possible to upgrade it via a driver?
Maybe it is possible to disable it and put an ISA OPL3 sound card next to it, for example Yamaha Audician?
I also read that several versions came out, for example AudioPCI 1000, 2000, 3000, 5000.
What is the difference between them?
Reply 1 of 3, by darry
I would try SBEMU instead under DOS for better OPL3 emulation
Reply 2 of 3, by envagyok
Thank you, i will try it
Reply 3 of 3, by chinny22
One often overlooked "trick" is to select General Midi instead of SoundBlaster when games allow it.
This will instead use the .ecw "soundfont" file
I think if you renamed the 8MB file as default it would it in dos, but not 100% sure on that.
Otherwise yes you could use 2 sound cards side by side, you can't disable OPL games will just output to both devices
