First post, by eddman
I don't mean games that run slow, but that simply don't work on a 486. I've been testing Dreams to Reality in 86box and with a 486 I just get a black screen. Switching to Pentium Overdrive on the same board makes it work. (EDIT: It's non-MMX OD since it's a 486 board)
I know that, for example, Windows XP doesn't work on a 486 because of a missing instruction.
Are there any games with such requirements?
EDIT: I tested the game again but this time in the windows 98 environment, and it works with a 486. The issue is limited to real DOS for some reason.
Reply 1 of 14, by Trashbytes
If the software makes use of the new instructions the Pentium bought in then it wont work on a 486 namely CPUID, CMPXCHG8B, RDTSC, RDMSR, WRMSR, RSM instructions. It could also fail if it doesn't find the the new FPU the P5 has and relies on it to function.
The other case would be if the software needs MMX instructions, IIRC there were Pentium MMX Overdrives, not sure they were ever compatible with anything other than socket 5/7 however.
Some software also simply looked for the CPUID instruction and if its wasn't present then it either gave an error message or simply failed to run.
Reply 2 of 14, by eddman
Trashbytes wrote on 2024-02-15, 23:21:
I thought that'd just make the game run slow and not prevent it from running. Do you know examples I could test?
Reply 3 of 14, by Trashbytes
eddman wrote on 2024-02-15, 23:35:
If the program doesn't check the CPUID then yes it may just run slower or run but with issues, if it does some basic sanity checking then it would simply fail to run and give you an error when executing.
https://en.wikipedia.org/wiki/Pentium_(original)
Describes some of the core changes the Pentium made, the FPU was one of the biggest changes.
Reply 4 of 14, by eddman
Yea, I had already read that page but thought games didn't care about those changes when it comes to basic compatibility. Even games from late 90s launch on a 486, so I didn't think there are some that don't. Another possibility from the example I posted in the OP is an emulation bug. Perhaps someone who owns that game can confirm.
Reply 5 of 14, by leileilol
The few that had strict Pentium checks were probably either 1997 "MMX" games (sweet intel money) or those that didn't realize there were other 5th/6th gen processors that don't satisfy Pentium checks so they're taken out before shipping (i.e. MDK) or shipped anyway (i.e. Bug!). Minimum requirements stating "Pentium" is also thrown more as a shorthand for having a FPU rather than specifying 486DX2 ro 4 which most could actually run but that'll have a confuse with 486SX.
Reply 6 of 14, by chinny22
I remember trying to play a few dos game demo's from magazine CD's on my 486 and getting.
"This game requires at least a Pentium Processor" and dropping back to dos.
Can't really remember the games (as I couldn't play them so no memories) but I think Destruction Derby 2 may of and been disappointed (even though DD1 already struggled)
Reply 7 of 14, by GemCookie
The Sims won't run on a 486.
[down] Asus Maximus Extreme X38 | C2Q Q9550 | GTX 750Ti | 8GiB | 120GB SSD+640GB HDD | WinXP/7/11
P3 866 | Riva TNT2 | 256MiB PC133 CL2 | 120GB HDD | WfW3.11/Win95/NT4/2k/XP/7
Dell Precision M6400 | C2D T9600 | FX2700M | 16GiB | 128GB SSD | Win2k/XP/Vista
Reply 9 of 14, by Cyberdyne
Windows 95/Direct X is really a Pentium+ era. But were there really a pure DOS game that absolutely needed a real Pentium?
Reply 10 of 14, by chinny22
Cyberdyne wrote on 2024-02-19, 16:05:
Destruction Derby 2 is a pure dos game, was released during that era when both a windows and dos version of the game was released.
https://www.mobygames.com/game/2546/destructi … -derby-2/specs/
Reply 12 of 14, by eddman
thepirategamerboy12 wrote on 2024-02-21, 02:58:
Slam City with Scottie Pippen won't run on anything less than a Pentium CPU, game will give an error stating such.
That's odd. On the box it says "25 MHz 486 processor or faster".
Perhaps a misprint.
Reply 13 of 14, by Jo22
I think there are DOS games which don't run a Pentium anymore. Or a late 486DX4.
They're making use of undocumented 486 instructions, which are merely present in the original 486 chip design(s).
That's what I heard, at least. One strategic flight simulator was affected, I vaguely remember.
Reply 14 of 14, by thepirategamerboy12
eddman wrote on 2024-02-21, 09:15:
Perhaps a misprint.
Just tried it again myself to be sure and this is what happens:
8.96 KiB
