First post, by Netscape
Hello,
I have this old 486 case (pictured) which I want to use with modern components. I plan on putting in a mini ITX motherboard and obviously a modern PSU. I wanted to use the original front rocker switch, but I am thinking this is not a possibility, at least I can't think of one. I just wondered if anyone had any ideas about this? Plan b would be to connect the reset switch to the power pins on the motherboard .
Thanks for any help
