Reply 26780 of 27568, by lti
I tried fiddling with the chipset registers on my HP Pavilion ze1210 craptop to see if I could get better performance. Enabling memory interleaving didn't affect performance significantly (I'm surprised that I could actually measure a 3% gain in the Sandra memory benchmark). I guess integrated video steals so much RAM bandwidth from the CPU that nothing helps, but video performance didn't improve either.
dominusprog wrote on 2024-02-18, 14:51:
GigAHerZ wrote on 2024-02-17, 18:12:
A different little piece of electronics that is more suitable for controlling the fans than lowering the voltage.
If you just want to lower voltage, you could just use a resistor. No need to use that fancy buck-converter. 😀
Since using the resistor will limit the current, is not a good idea to use one.
The modern Noctua low-noise adapters are just a resistor. There are lots of different ways to control fan speed, and they all have the problem of the fan not starting if you try to slow it down too much. The PWM controllers will usually run the fan at full speed for a brief period on startup to make sure it spins up reliably.
Reply 26781 of 27568, by ssokolow
gerry wrote on 2024-02-19, 15:18:
ssokolow wrote on 2024-02-19, 07:19:
Reminds me of the 19" Dell LCD I was given many years ago (I'd already had it for years when COVID hit) with a broken power button which has been serving as the rightmost of the spread of three monitors on my daily driver PC ever since.
My solution there was to fill the hole for the button with hot glue to make a frosted window for the LED, drill a hole in the plastic over the actual location of the pushbutton, cut the top off a clear pushpin, and then wrap some trimmed electrical tape around it to keep it from falling out:
nice! there's a lot to be said for hot glue and fillers for such fixes- keeps things functioning but without having to buy or product exact replacements
I'd have tried to come up with a better solution if I'd expected it to last as long as it has. At the time, I chose a "thing I can never undo" (drilling a hole in the case) because I expected it to give me a few years and then be just another of countless 19" LCD monitors that either die and get thrown away or have their PSU boards recapped.
(See, for example, my Power Mac G4 as a contrast. I've had the "use an ordinary ATX PSU" cables for months, but I haven't had time to figure out how to research what PSU to buy so the only things which project from it will line up with the existing precise "power socket and 110/220 slider" cut-outs on the back of the case and avoid the need to cut up a G4 Quicksilver case... either that or see if there's a normal ATX PSU cut-out beneath that plastic moulding and, if so, if it's possible to safely and non-destructively remove the back plastic and box it up. That just occurred to me.)
Internet Archive: My Uploads
My Blog: Retrocomputing Resources
My Rose-Coloured-Glasses Builds
I also try to announce retro-relevant stuff on on Mastodon.
Reply 26782 of 27568, by BitWrangler
I tend to take an approach that goes "mod things towards more standard" meaning, unless it's a complete Frankenstein from several different pieces of junk, to try for a clean mod of something that takes a weird part, to take a standard part, rather than going for modding to splice an almost right also weird part or something.
Reply 26783 of 27568, by Tiido
I found my old Covox :
296.87 KiB
287.59 KiB
I built it I think in 2005 but maybe 2004 or such, and because the computer I got had no ISA and no sound in DOS games and this was a way to get at least some sound. I could also make it do sound from my own programs too ~
Model number says it is the second iteration, but I have no memory of the first one...
I remember it was a bit of a struggle to find suitable resistors, 10k was easy but 20k not so much...
Reply 26784 of 27568, by ssokolow
Tiido wrote on 2024-02-21, 05:05:
I found my old Covox : Covox0.jpg Covox1.jpg I built it I think in 2005 but maybe 2004 or such, and because the computer I got h […]
I actually have an attempted Covox which I thought was screwed up and was planning to ask for "what am I missing in these circuit diagrams other people had no trouble with?" EE help on that I've been meaning to re-test because it's possible the mistake was in replacing the hard-wired cable on the computer speakers.
(I don't think I only tested with one pair, but it's entirely possible and that pair later turned out to somehow have gotten miswired while I was replacing the bad cable, resulting in the left and right channels cancelling each other out when audio is mono/centered.)
Funny enough, I originally built the thing just because I thought it'd be a fun, nerdy EE project but, now that I've got an HP t5530 thin client, I think I'll test out Virtual SoundBlaster to see if it produces a DOS option faster than running DOSBox on Win98SE on an 800MHz VIA chip, more compatible than Windows 98's WDM SoundBlaster emulator, and less "crash the whole system hard when I test with Skunny Kart" than SBEMU.
Reply 26786 of 27568, by Thermalwrong
LCD panel transplant - the original looked like the LCD layer was delaminating so has these weird squiggles at the edges of the display:
766.4 KiB
I went into my parts bin of LCDs and found a similar lq121s1lh02 - 800x600 LCD that runs at 3.3v, the laptop gives 5v to the LCD. I tested the backlight and the backlight has bright spots and dark spots all over it, rubbish. The fresnel sheets look like they got scratched or are starting to go moldy - they are being stored essentially outside right now 🙁
Tried something I've never done before which was putting a different LCD panel in place of the original damaged LCD panel. The mini grinder tool made it possible and the backlight sheets made it through the transplant operation mostly undamaged.
I had to cut lots of plastic from the frame to make it fit but it's looking good and lights up the whole pixel area of the LCD just a little adjustment needed still. There's an AMS1117 converting 5v into 3.3v so the LCD panel electronics don't burn up, and the new panel's pinout is different from the original so some minor rewiring of the LVDS pairs was needed, but it works.
The repaired LCD looks great except for a bright line at the top but that doesn't notice too much in use, compared to the squiggles or bright spots. This means I've got one very nice LCD screen from 2 useless ones 😀
Reply 26787 of 27568, by Thermalwrong
Me again 😀 New topic though because I fixed one of my video cards - it's been sitting around on my desk for a week or two. I couldn't figure out why this Medion Geforce 3 Ti200 could display 2D perfectly but would restart the system almost immediately when running any 3d stuff.
I was going to set up a secondary test system doubting the AGP power output on my MSI 865 P4 testing system - but that wasn't it. The card has been sitting on my desk for a while and I looked in its direction at a different angle today and spotted one of the capacitors sitting at a jaunty angle:
1.02 MiB
The purple polymer 4v 510uF capacitor had one leg broken off completely somehow. That I think was the filter capacitor for the voltage output of the GPU VCC rail, replaced it with this red poly-cap salvaged from another motherboard/card years ago and now the card is working 100%
edit: nope, it was the 3.3v input to the voltage regulator for GPU vcore. Which is why there's just one. The two poly caps next to it are the GPU vcore filter caps.
This is actually pretty interesting - there's an FX 5700LE card that did basically the same thing with crashing on 3d although 2d was perfect, perhaps it needs recapping.
Reply 26789 of 27568, by appiah4
Started soldering some AmigaMidi boards. The passives are done, I'll likely get them finished tonight.
Reply 26790 of 27568, by Shadzilla
I got outbid on an AMD Athlon XP 3200+ Barton 400MHz CPU.
There were a lot of people watching it and it was up to just under £20 for most of the last day, so my gut was telling me it was very likely to go for more than the roughly £40 the last one went for. So with about 20 seconds to go I put in a bid of £75 - which is a lot don't get me wrong, but less than buying one from mainland Europe at the moment - expecting it to end somewhere in the £50-60 region. It was on me for £45 until a second or two at the end, when I was outbid and it went for £77.
Absolutely astonishing. I guess someone else really wanted it as well!
So with my tail between my legs, I ordered an almost identital XP 3000+ - same core, same stepping - from Germany for about £34. I'll know that it's not the absolute top dog, but it's close enough for now. And I'm pretty sure the nForce2 board it's going in will happily let it run at 3200+ speed anyway.
Reply 26791 of 27568, by gerry
Thermalwrong wrote on 2024-02-22, 02:47:
LCD panel transplant - the original looked like the LCD layer was delaminating so has these weird squiggles at the edges of the […]
that was something of a risk but it went well! a good way to use an officially 'incompatible' part
Reply 26792 of 27568, by Shponglefan
zuldan wrote on 2024-02-23, 07:36:
Installed some cooling for my Voodoo 3 3000
I don't think that's enough cooling. You need at least one more fan. 😉
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 26793 of 27568, by appiah4
Well, that took a while, but my Atari ST emulators are done. And now that they're done and it feels good to have done it 😀
Reply 26794 of 27568, by zuldan
Shponglefan wrote on 2024-02-23, 17:49:
Maybe I need to underclock it to try improve the cooling 😉
Reply 26795 of 27568, by smtkr
I did an LCD transplant last year. The new LCD I put in had a refresh rate significantly better than the original, as well as better contrast. I did it for fun. I haven't used the panel since initial testing to make sure it works. I'm kind of curious if the faster refresh rate will be noticeable, or if the control board is too old to drive it fast. Something to test in the future, I guess
Reply 26796 of 27568, by vutt
Treated my 486 setup with new Rubycon caps. Original ones looked beaten. However after running them trough my bench LCR comically old ones measured closer to 220uF then brand new Rubycons. Still new ones were well in 20% spec.
ESR @100khz was slightly higher for one old one at 0.23Ohm compared to rest with 0.15Ohm measurement. However I don't think it's critical.
I was slightly worried that old ones were rated only at 85C while one of them is located right next to voltage regulator with spec temp oner 100C. With my Am486 DX2-80 I measured regulator temp 75C.
Then again board is 30 years old and still working so 85C was good enough...
I also added brand new heatsink to CPU. Seems to be good enough. During multi hour stress test it never reached 50C. Farnell/Element14 is selling them with thermal adhesive pad attached. Quite convenient.
Also joined finally theretroweb.com community and made my first contribution by sharing better quality MB pic.
382.37 KiB
1.87 MiB
Reply 26797 of 27568, by Joakim
I was going to fix the missing caps on my 8 mb voodoo 2 I got years ago. Did not get it to work. Gets stuck on 3dfx logo. So I put an other voodoo 12 mb in there instead.
It did not work either... Had a look at it and yeah it also has a missing cap otherwise it looks fine. Sadly I don't have that cap at hand.
Ok then I try my other voodoo 2 12mb card. Also this did not work. It has a bent pin on one of the tmus. Its not shorted or so but it might be cause if the problem.
I am sure one of these two 12mb worked 2 years ago.
So now I'm a bit bummed out as I realize I don't have a single working voodoo card when I thought I had at least 1.
I need to cool my head a bit and try with an other computer that at least has a good way of transferring files and that is in a tower case.
What demos are good for testing voodoo 2s? What are the most stable drivers? All of the cards are Creative labs.
Reply 26798 of 27568, by H3nrik V!
Upgrading my Dell Precision M4400 Laptop with parts from the recycling store;
Double memory 4GiB -> 8 GiB
Double number of Cores 2C -> 4C
Quadruple amount of cache 3MiB -> 12 MiB
Core2Duo Mobile P8700 -> Core2Extreme Mobile QX9300
Oh, and the donor had a Mobile Modem as well, which also came over 😀
    409.51 KiB
    P8700 vs QX9300
Reply 26799 of 27568, by RaVeN-05
i streamed NASCAR Racing 2 on retro PC under Rendition Verite video card 🤣 https://www.twitch.tv/whitemagicraventv
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
