Reply 2180 of 2381, by BitWrangler
 - l33t++
Socket3 wrote on 2024-02-13, 07:05:I'm not sure what to do about the componentes stuffed in boxes, I don't want them under the desks. One idea I had is to buy kitchen cabinets - the kind you install on the wall, and install them on the walls above the desks.
If you are in Canada, I noticed they have garage wall cabinets on sale in the flyer this week, $149 CDN for a double wide. Not dirt cheap, but reasonable. Other place to try would be the Habitat for Humanity ReStores (Which occasionally also get in computer stuff)
If the shelving is still a problem, and you've got identical heavy duty units, you could use them as "ends" and bridge them with sturdy planks between them for a section of shelving between them. Only as wide as they are if it's heavier stuff, but could go 8ft even if it's light stuff like game boxes on it.
