First post, by zzgus
Hi community !
Recently I'm into retrohardware another time now that I have some free time.
With all my enthusiasm this week I bought a near mint Tulip 386 computer, but at the first boot I could hear a kind of buzz and some smoke smell.
After opening the case I could see a squeezed cable from the power supply. (see pictures attached)
After further investigation I see a "component" of the riser card burnt. (see pictures attached)
What will you guys do next?
- Test power supply values?
- Change burnt component ?
Thankyou
Gus
    233.46 KiB
    284.65 KiB
    296.85 KiB
    99.79 KiB
    108.9 KiB
Reply 1 of 18, by weedeewee
Look up 'tantrum capacitors' or correct name 'tantalum capacitors' and their propensity to blow up.
then just cut the offending part off, because it is likely to be causing a short on a power line, stopping the power supply from working properly, and test the mainboard again, and expect some other tantrum capacitor to blow.
and don't worry too much about it.
edit: that squeezed wire, is that white or yellow? either way it shouldn't matter for an old 386.
Do not ask Why !
Reply 2 of 18, by zzgus
weedeewee wrote on 2024-02-23, 10:29:
I don't really know what do you mean sorry... Cut the burnt yellow "component" and test motherboard again?
The component burnt is on the riser card, I have took apart the riser card and also no luck booting up.
The wire is yellow.
Thankyou
Gus
Reply 3 of 18, by BitFlip
zzgus wrote on 2024-02-23, 10:40:
I don't really know what do you mean sorry... Cut the burnt yellow "component" and test motherboard again? The component burnt […]
The wire is yellow.
Thankyou
Gus
You can just cut the burned capacitor off from the board or de-solder it then boot the system to check its working, I believe the tantalum its only there for filtering and as you can see there's 2 other in parallel with the blown one.
Reply 4 of 18, by weedeewee
Cut the burnt component off of the riser board. The one you pointed an arrow to on the photos you posted.
You say the mainboard without the riser is still not giving you anything.
Does the power supply come on and can you measure the voltages? you should find +12v, +5v, -5v & -12v on the power supply mainboard connector.
Do not ask Why !
Reply 5 of 18, by zzgus
weedeewee wrote on 2024-02-23, 10:53:
Yes I can see the fan spin... I'll measure the voltages.
Thankyou
Gus
Reply 8 of 18, by rasz_pl
You dont even have to replace it, in the eighties there was no power analysis software used when designing motherboards, engineers just sprinkled capacitors on the whim/hunch.
Reply 9 of 18, by weedeewee
zzgus wrote on 2024-02-23, 17:11:
BTW what's this ?
It's a 'tantrum' capacitor (tantalum) and as rasz_pl said, you don't have to replace it.
Do not ask Why !
Reply 10 of 18, by megatron-uk
BTW what's this ?
It appears to be a 4.7uF 16v tantalum capacitor. Readily available:
https://www.mouser.co.uk/c/passive-components … g%20dc=16%20VDC
But, as said, they are not always essential components and were often fitted to "cross the t's and dot the i's" - i.e. belts and braces approach. They are often doubled up and scattered around the board seemingly at random.
As you've found out, unlike normal electrolytic capacitors which usually don't go bang (but instead leak, and puke their conductive/corrosive guts up), tantalums tend to go BANG, and sometimes fail in a shorted state.
https://www.target-earth.net
Reply 12 of 18, by Deunan
megatron-uk wrote on 2024-02-23, 17:26:
You haven't tried hard enough 😀 They do go bang too, and tend to leave quite a mess when they do. Though it is very rare for low voltage electrolytics to go bang with nominal voltage applied.
Reply 13 of 18, by PD2JK
It looks like that yellow wire was pinched.
Is the wire exposed? if not, don't worry about it.
I serviced a few TCX17 power supplies, can you measure the 5 and 12 V rails during a cold boot? Sometimes they are far too low. When warmed up, they become within tolerance range.
Reply 14 of 18, by megatron-uk
Deunan wrote on 2024-02-23, 17:49:
Tell me about it. A wrongly wired PSU on a freshly recapped Sharp X68000 (courtesy of a mistranslated wiring diagram and swapped +12v / -12v colours on the schematic) and I had 3 or 4 cans blow up and launch their innards across the office.
Motherboard ended up toast. That was an expensive failure.
Smelled great, as well!
Reply 15 of 18, by aaronkatrini
It is a Tantalum capacitor (value = 4.7uF/16V). It is common for these to go bang with time. Nothing to worry, most of the time they just fail this way but don't take anything with them. So just replace the capacitor (or just remove it completely) and the board should start right up. Also it would be best to replace them all with electrolytic ones. Cheers!
Reply 16 of 18, by whaka
rasz_pl wrote on 2024-02-23, 17:18:
but there already was a thing called oscilloscope... and this thing had the ability to show noise on power rail, you know 😀
so it's still a good idea to replace it. but i admit it could probably live without it with no big issues.
Reply 18 of 18, by Errius
A capacitor burst on one of my Acer USB cards, spraying molten gunk over the neighboring card, a Highpoint RAID card, also killing it.
Is this too much voodoo?
