First post, by Kahenraz
I have five Voodoo 2s; three Creative CT6670 (8MB) and two Diamond Monster 3D II (12MB). Both of my Diamond cards show a screen door-like appearance on the 3dfx logo, as well as strange lighting when playing Quake.
I'm fairly certain that this is telling me that one of the memory chips is bad, but I thought it was odd that it was only on the two matching 12MB cards. Are there any issues resulting from the extra memory that could be causing this problem or is this confidently a bad memory chip somewhere?
The attachment 20240223_231915.jpg is no longer available
Reply 1 of 6, by Trashbytes
Sure does look like one of the two has bad memory if they are in SLI, if they are both doing it in single card mode then they both have memory IC problems. My guess is there is a bad memory IC on one of the two TMUs as Frame buffer memory would give a different type of corruption.
Reply 2 of 6, by Kahenraz
They each display this problem in single card mode, although with a slightly different pattern.
I'll have to find some replacement memory that is compatible.
Reply 3 of 6, by MikeSG
Do you have any other images of the issue? If it's just colouring, I'd lean more towards the analog circuit (eg. capacitors)
Reply 4 of 6, by Kahenraz
I've already disconnected and packed it up. The dot pattern also exists on textures in Quake 1, which makes me feel it's something wrong with the texture memory, or maybe a loose pin on a TMU.
Reply 5 of 6, by Trashbytes
Kahenraz wrote on 2024-02-24, 08:45:
Its weird they both got the same issue at the same time .. is it possible they got a bit more angry pixies than they should have ? Even a slightly higher PCI voltage than spec may cause older ICs to fail.
Though if both cards were fabbed around the same time old tired solder might be worth checking out.
Reply 6 of 6, by Kahenraz
I believe that both of these were fully dead at some point and I revived them by reflowing all of the large QFPs. I seem to recall the legs having cracked and being manipulatable with a probe. One of them has bent legs that I also repaired.
These were one of my first large QFP repairs, and I've gotten a lot better since then, so maybe they need to be revisited. I cleaned up the legs and added fresh solder though, so it would be odd if it's the same problem as before. They have since been living in a small bin within their own individual antistatic bag and were well protected.
Edit:
I found the repair log here:
Voodoo 2 triage and repair
This thread is actually from one of my working cards, but the dot pattern can be seen in one of the photos where I had a solder bridge on a TMU. This suggests that it might be loose QFP legs, like I thought. I feel that these components work themselves loose if time due to repeated thermal expansion, since they have no heatsink and tend to run very hot.
