First post, by boggsman
I just ordered a Compaq ASPEN2 board. Does anyone know if I can flash the ASPEN2 board with the FIC SD11 BIOS?
Reply 1 of 5, by Horun
Theoretically yes you can. Do you have a eeprom programmer like TL866 ? That is the only way I would try to flash the bios chip AFTER I saved the current bios using TL866 to both save and program.....
Reply 2 of 5, by boggsman
No I don't
Reply 3 of 5, by boggsman
It looks like there are some cheap ones on aliexpress
Reply 4 of 5, by boggsman
The bios chip on the ASPEN2 is square. The eeprom adapters in the kit have pins on 2 sides.
Reply 5 of 5, by Horun
You use a PLCC 32 to DIP 32 adapter for PLCC 29f002 eeprom (and is rectangular not square 😁 ), my TL866 came with a few adapters including the one needed....
like: https://m.media-amazon.com/images/I/41T7sVqjAoL.jpg or similar
