Reply 220 of 299, by Falcosoft
- l33t
Trelokk wrote on 2024-03-01, 17:01:We might have a problem. With your latest version, MIDI music suddenly sounds wrong. To be more precise: Wrong instruments are played. I tried with the 2006LE first and thought it's the plugin, so I switched back to the XG50. But it was the same thing.
It didn't happen all the time, but for sure with D_E1M8 of Doom. The song is suddenly brutally butchered, not recognizable at all any more. It wasn't like this with the previous driver version (2.2.0). Tested with Woof! and GZDoom.
What Midi client you used exactly when you experienced this, and what is the process in steps I should do to be able to replicate the problem?
BTW, you can try 2 things:
1. Set XG/GM/GS reset from the system tray menu.
2. Try to disble KeepDriverLoaded from the registry:
HKEY_CURRENT_USER\Software\VSTi Driver \KeepDriverLoaded = 0
@Edit:
Unfortunately I could not reproduce your problem. E1M8 sounds good to me in case of GZDoom:
https://youtu.be/o2f2_zUc508
